What storage access size in garage ceiling?
shingo
Illinois
I've got 10 pounds of sh!t and I live in a 5 pound world.
My new garage is going up on Monday and I am having a storage area above the cars built into it. 16" oc rafters will support 3/4" osb sheathing for the full length and width of the 18' by 20' garage. I want to keep it simple, just a scuttle hole which I will put a short extension ladder into when I want to put things up there. What size opening should I go with? Bicycles and boxes and long term storage going up there. Should I go with 36" or 48" for width? And what about length? Is four or five feet enough?
HoosierBuddy
Southern Indiana
IIWY, I'd at least look at the required rough-in opening for pull-down stairs.
Whatever that size opening is will be a standard size and has been designed to be adequate for some things.
Also, you might one day want to put in some pull down stairs. I had them at a former house and they are a pain in the ****, but better than nothing.
I have no idea what that size is though.
Phil
hh76
NE Wisconsin
As big as possible.
Trying to squeeze over sized stuff through a small opening is tough enough on the ground, dangerous when your at the top of a ladder.
I'd go for a 32" opening minimum, and 4' if possible.
Falcon67
Merkel, TX
Nothing smaller than 24" x 48". My old shop had 4 panels 48x48 that could be moved for access, that worked well.
