What style is this ratchet? (looking for a clone)
peejay75
Have this Duralast 72T 3/8 ratchet, and would like to find a 90T quick-release version (if such an animal exists), to fit in the blow-molded case. Thanks for any help!
^ unless I am mistaken, Tekton publishes physical dimensions in their online catalog.
I do not own any 3/8" drive Tekton. I do own the 1/4" drive equivalent to this model - 90T/QR - and it has a fabulously smooth action.
P
peejay75
I was hoping they have measurements, looks like the original ratchet I hope to replace is "shallow", will report back once I have all the info!
Edit:
Ok, here's what I found on the Tekton SRH11108 specs, Duralast [tape] measurements in red:
^ The Tekton 1/4" model I have does have an overly long handle. None of my other 1/4" drive ratchets are that long.
Might not fit into that box without modifications.
I think @BlakeTheCarGuy uses a lot of "Duralast" - I'm not familiar with that product line because I hardly ever go into those parts stores.
P
peejay75
Good to know about the overly long handle, thanks! I'm gonna add my Hart 3/8 ratchet to the measurement pool and see if there is a "standard".
Steve_P
You might also check out the Gearwrench and Capri 90T models to see if you find a better match.
P
peejay75
Will do! (Edit...Capri: looks right, only 72T that I can tell,90T are comfort grip and non QR; Gearwrench: looks right, 90T, need to find more pics/dimensions).
The Icon models have the same look and are 90T, but no quick release.
This WORKPRO model looks like it would work, but only 72T.
So it may come down to which is more important to me, 90T or quick release. Never used non quick release ratchets before, so I should play with this Duralast one first and see if I'm missing out on anything.
(Edit: Snap-on F80 looks to be the original "shape".)
WWheeler
Middleofnowhere USA
Here's the original that everybody copies. FR80.
Definitely the shape so many copy to some extent, at least as far as the handle goes, but Snap-on has been using that same basic shape for their ratchets for more than a few decades before that FR80 which first came out around 2012 iirc. I've still got a few 30-tooth gen Snap-on ratchets that have that same shape as my Dual 80s, and I believe the generations of Snap-on ratchets that preceded them did too.
Just for example, here's a 1/2" S936 (36 tooth) that's at least 25 years old next to a 3/8" F80 that's about 10 or so.
^ I have a little 1/4" model with the same handle that was produced long prior to that design.
looks like "Husky" used the same handle design at some point as well.
P
peejay75
Thanks for the history lessons, members!
Also, looks like this Boxo wrench may come the closest (no QR), but more than I'd care to spend, so maybe a Father's Day gift!
P
peejay75
Perhaps this SATA 3 pc set will fit your needs? $25 for the set of 3.
SATA is owned by APEX tool group, just like GearWrench, Crescent, etc.
The 3/8 is 72 tooth.
From the Q&A
Thanks! I may hafta give that a second look! Reason I say second is, I recall coming across that ratchet during a search (didn't know about the 3-piece set, which I would eventually want!), but the dimensions for the 3/8 under the specs show > 8", but that could be including packaging and what not, so the numbers you posted look better...maybe I should gamble on the 1/4" first and go from there.
WWheeler
Middleofnowhere USA
Amazon "product dimensions" are almost always the package size, though that seems small given it was answered that the 1/2" dr is 9-1/2", so .... Maybe they are packaged at an angle with that 1/2" dr corner to corner? IDK.
Really isn't much of a gamble for $25 for a 3 pc set, plus it's Amazon so within 30 days it can be returned for most any reason (and if so, then someone else here at GJ will probably snag that set for $16.99 on an Amazon Warehouse deal ).
P
peejay75
Okay, small update...
I found and ordered this PRO-GRADE ratchet (not 90-tooth, but is quick-release), supposedly it measures 8", will report back when it comes in.
Citation
Indy
Looks a lot like an Icon ratchet... or more truthfully, Icon gets their ratchets from the same source.
P
peejay75
Looks at like an Icon ratchet... or more truthfully, Icon gets their ratchets from the same source.
The Icons are the right look, but the short version is 7-5/8” and the long is 9-1/16”, curse you, Duralast, and me for liking you!
Edit: Forgot about Titan, their 68101 (72T, QR) has the FR80 look, specs indicate 7-3/4” OAL.
P
peejay75
The Pro-Grade ratchet came in, it fits the case pretty good! It's slightly smaller (~7-13/16” OAL) and thicker at the head than the Duralast one, but the case closes!
The direction lever is plastic, never seen that before, so I will be wanting to change that to a metal one, as well as replace those phillips head screws with torx, to look like everyone else's ratchet! Can anyone point me in the right, ahem, direction on finding the best source for upgrade parts?
Then I'll move on to the 1/4 and 1/2 ratchets!
P
peejay75
Bought the WORKPRO version because it was on "sale", and specs showed 7-3/4”. It's nearly identical to the PRO-GRADE, but better. The direction lever feels more solid on the WP. I put a magnet to both levers, they are both metal, but the PG feels so flimsy/had so little magnetic attraction that it almost feels metal plated. Will use it as a throwaway or parts ratchet.
