What surprising tools don’t you own...
Want2race
I feel like there aren’t many tools I don’t have. Having mills and lathes makes me pretty confident in my collection.
Today I needed to hand cut a piece of wood and realized I don’t have a single handsaw besides a hacksaw. I guess in all my years (pre kids) I didn’t have to worry about noise.
What tools are you shocked/surprised you don’t have and why?
jumbojak
Surry, VA
The big one right now is a table saw. I was looking at getting one, doing my research, and then The Plague hit, so any purchases like that are put off for the foreseeable future.
ericlar80
California
Unless you really need a table saw, I would get a track saw. Love mine and more versatile if you already have a sliding compound miter saw.
James-W
Southeastern Wisconsin
A track saw is wonderful for some things, and there are times when I wish I had one, but a table saw is handy for just about anything. For example, a couple days ago I ripped a 2X8 into strips an inch and a half wide and half an inch thick.
If you don't mind my asking, what model track saw do you have? I would really like to have one for cutting plywood. Is there one you would like to recommend more than others? I don't need one for everyday usage, just for when I need to cut a piece from a full sheet of plywood.
I currently cut plywood with my table saw. But a 4X8 sheet is a bit clumsy to cut on my table saw if I want to cut off a piece 10 inches wide and 4 feet long. Cutting off 10 inches wide by 8 feet long is fairly easy, or if I have a smaller piece of plywood I have no problem cutting it.
I would like to have one of these, but first of all I don't have room for it and secondly, I wouldn't use it anywhere near enough to justify the cost.
https://www.homedepot.com/p/Milwaukee-15-Amp-8-1-4-in-Panel-Saw-6480-20/100077431
ericlar80
California
I have the Makita track saw with the 55" track. The only thing the track saw is not great at is cutting a narrow piece of wood even narrower. Pretty much everything else it can do, and it excels at cutting down plywood to any straight-sided shape. The table saw is going to be more repeatable on strip cuts, but the track saw is surprisingly accurate due to the rubber piece that helps you align the cut and prevent tear-out.
I built a nice cabinet box using my track saw that I never could have done with my medium-sized table saw.
ericlar80
California
Here is a part of the box I built, and the completed cabinet. (I bought the doors from Barker door.)
jumbojak
Surry, VA
I've thought about a track saw in lieu of a table saw but one of my big uses would be cutting down narrow strips. For large sheets a regular circular saw and a straight edge can be made to work - I love my mag sidewinder - but squaring small stock is nearly impossible. I don't think that a track saw would do the job any better.
A miter saw would come after the table saw. Crosscuts on longer pieces aren't a common use-case for me and, with a sled, the smaller crosscuts can be done on the table saw. A zero clearance slider would be nice though. I figure I can make stands for both and save that money.
matt_i
A snow blower.
A shovel has gotten me thru for the last 10 years.
I realize I'm not getting any younger so a tractor-plow setup/adaptation is awaiting its turn on the center stage.
Ron_J
Central PA
Nothing comes to mind, but once it does, I'll be sure to run out and buy one. :(
I would have an easier time naming the tools that I have and never use.
Motorman55
South Jersey
Don't get me started....but a few things that come to mind right away; Bandsaw, Battery powered yard tools...I'm still dragging around cords. Ride on lawn mower...and lots more.
orangeblood
Texas
palm router...recently upgraded my old usa 3/8 fixed cman to a new 1/2 makita w/ a separate plunge base. the versatility is a night and day difference and it causes one to think of all of the things they could / should have done better with a good router. the secondary effect is causing one want a small palm sized router for lighter work that doesnt get done because you dont want to handle the bigger unit and set up.
any recommendations from advanced router users?....makita?
exranger06
CT
Cordless tools. I don't own a single cordless tool. All of my power tools are either 120V corded or pneumatic.
OccupantRJ
Eastern North Carolina
Portable air tank. With a shop that has capability to do almost anything, a simple air tank. I do have enough hose to reach around the house to the front yard, though.
Bogie1632
Air compressor. Like...a good, large one. I've got a 3 gallon CM that works well airing up tires or occasionally running a brand nailer. Impacts, grinders, air drills, etc... Not so much. Usually when I need a new tool I just go get it (or the set) when the need arises. Have yet to pull the trigger on a compressor so I just suffer along breaking lugnuts free by hand like I'm stuck on the side of the road...
V/R
Bogie
gnpenning
I have more questions than answers.
How does a stacked dado work in your track saw??
I don't have a track saw. While I think they would be better than the clamp down guides I use to cut down larger sheet goods, I haven't decided if it's worth it for me.
James-W
palm router...recently upgraded my old usa 3/8 fixed cman to a new 1/2 Makita w/ a separate plunge base. the versatility is a night and day difference and it causes one to think of all of the things they could / should have done better with a good router. the secondary effect is causing one want a small palm sized router for lighter work that doesn't get done because you dont want to handle the bigger unit and set up.
Any recommendations from advanced router users?....Makita?
I have this router and I use it a lot for rounding over edges on projects. It is small, it is easy to use, and it works great. I have several routers but this one gets the most use.
https://www.homedepot.com/p/DEWALT-...r-with-Plunge-Base-and-Bag-DWP611PK/203054747
TractorJeff
Elkhorn, WI
Is a person a Tool?
If so I need one to do all the remodeling **** in the house that my wife wants done!
Seriously I have most Tools and have gotten rid of quite a few extras.
Do need a modern Belt Sander. I have my Great Uncle's 1960's Craftsman which it is getting harder to find belts for!
crewchief888
NW indiana
no plasma, I sold the one I had 10 years ago.
no router, havnt NEEDED one yet
OBII scanner only needed one 2 or 3 times over the years, and I can borrow one if I need to
120V pad sander, mine crapped out last year, and havnt NEEDED one since.
new tool/equipment buying has been on the decline over the past 7 or 8 years. I don't buy anything unless I NEED it.
:beer:
555
Nomad-Arkansas & Georgia
Anvil. I needed one last night but have not had one in over 20 years. It doesn't need to be anything more than a piece of railroad track or I beam. Just something to beat metal into submission. Ironically nearly all my grandfathers were blacksmiths.
wondo
Fowlerville, MI
I would say I use my palm router 4:1 vs my larger fixed base or plunge router. I think you need one!
niget2002
Josephine, TX
Spindle sander. I have an attachment for my drill press, but I could really use a standalone one.
I'd like to get a mill and lathe, but I'm not there yet.
Sent from my LM-G820 using Tapatalk
CJM8515
Coulda used a tablesaw many times but always made due. Now I just borrow my buddies.
LS6 Tommy
Northern NJ
A Dremel. They seem more of a toy than a real tool and I can do most everything with a die grinder that I need. Then I see people using them all the time and wonder if I need one??
You'd be surprised. I have a pneumatic die grinder and a REALLY nice electric extended neck die grinder I used to use to do port work. Even with them available, I use my Dremel for most all of the more delicate work these days. It finally died last fall after 30+ years of service. Heck, it worked a lot of connecting rods, ported a bunch of heads and intakes. It owed me zilch. I think the kit was probably $30.00 new. The one I want to get now as a replacement is $200.00.
Tommy
engineer2
Chicago burbs
I don't own a long-handle sledge hammer.
Don't own an extension ladder.
I could use mill, lathe, or a welder a couple of times a year.
I also no longer own a handsaw. Rarely use my hacksaw, except for once in a while for EMT.
