What the heck is this thing???
Hounddog
NW Florida
Unsure if the top picture shows it well enough but there are two round eyelets of sorts on the top of the rounded unit. There is a cotter type pin that attached s to one of the eyelets and that pin holds in place that section in picture 2 that I have in my hand. Also, that item is a solid pine shaft that fits perfectly in the inside diameter of the pipe that you see that is over the wood shaft.
H
Hounddog
NW Florida
I tried the musical instrument theory today....held it by the eyelets and used the 'mallet' ?? as a gong... Sounded like ****...Need more COWBELL....just not this cowbell!
rlitman
Long Island
My guess is a protective cover for some sensitive part, perhaps for shipping.
Maybe a "remove before flight" item?
EJM02
If I'm seeing the color correctly, that looks to be olive drab? If so, I'd bet it's a military surplus item and if that's the case, it could be a thousand things. I'm leaning toward some sort of attachment to a Willy's Jeep or maybe part of a recovery tool kit for one. Just a shot in the dark there..
Fugio
It looks like something you'd use to take dents out of brass instruments. But I don't think so because I used to do that in the early 80's and we pretty much just shoved ball bearings through them for that.
gungatim
west mich
no idea but I like the millitary scenerio. maybe it was for shipping something, like holding an antennae down in transit, something like that. clearly purpose built.
I wold think if it was millitary there should be some sort of marking on it? did u look real close for any stamping or anything?
EJM02
Also the red tape marks are indicative of something. Any other wear marks or dents in a particular place? Where did you find it or how did you get it? My curiosity is sort of killing me on this one for some reason.
Fugio
I keep thinking the wood is supposed to float when water gets in the tube. And maybe the hole is for pressure relief when they line up at a certain point. So maybe either some sort of flood control valve or part of some sort of elaborate water level system?
Ok probably not, but that's my guess and I'm sticking to it!
H
Hounddog
NW Florida
The fella I got it from (deceased) was a weather man...had saved a lot of weather stuff/equipment. Worked out of a small municipal airfield since the 60's. That's all I got. His 75+ yr old son had no idea either.
zkling
Some type of manometer or pitot? :dunno:
Or maybe it is just something to screw with those he left behind.
H
Hounddog
NW Florida
It is a shotgun barrel extension for when you want to take out the person right behind you.:lol_hitti
It looks like the end of the wooden dowel is pretty heavily worn, so whatever it is the dowel/cap part must have been installed and removed quite a few times over its' life.
**There is significant wear at the end of the dowel. And the dowel does go all the way thru.
That's an interesting shape on the end of the cotter pin. It doesn't look like it would hold in place very tightly because the tip of the cotter pin is the same diameter as the rest of the pin. How easily does it pull out?
**It's a cotter pin that had a ramp of sorts (angle) filed away (so it wont back out) The pin needs to be spread out and that keeper feature would work again. Now it's loose.
Is the hole in the tubing wall smaller on one side to better allow the cotter pin tip to click and lock into place via a slight spring pressure?
Does the wooden dowel piece go all the way through the metal cap attached to it or is the cap piece all metal on the end?
Neat find. I am interested to know what it ends up being.
**The son mentioned that it could have been used to check tires...he didn't seem too solid on it so I took it as a guess. while the removable piece functions like a mallet. It's use could have been to wack a tire OR A MOLE!!! (Obscure game reference)...like truckers do. And maybe the horshoe piece could have been used to gage the width of the tire??? paying attention to the highlighted area in red (as if its the only true measurement/reference point) Would have been a narrow tire. It does appear to be authentically old. Maybe a jeep tire????
***Thanks all for playing...
Davidad1
If the guy you purchased it from worked at an airport , maybe it is a wheel chock and tire thumper for the airplane tires
furbyj1
Miami, FL
Whatever that thing is, it doesn't look complete to me. I feel like its a piece or section of something bigger.
Are there any stamp or markings anywhere on it?
EJM02
Eh. Not enough weight in that set up to really test a tire. Just not enough momentum in the handle and the metal it's enough to let a person know if a tire would be flat. I'm beginning to think its a portable military dinner bell
Lippyp
Shropshire, UK
It's an experimental shaped charge for covertly blowing up someones toilet developed for the CIA to assasinate foreign dictators on the crapper, fits around the U bend, you didn't pull the pin out did you? did you? 5....4...3...2.....:Toilet:
LordPsychon
In your basement...seriously, go look now!
You know that weather man comment made me think it may have been used to measure pressure - one end is sealed and the other open to see the pressure difference in barometrics. What leads me away from this is that it's not clear and I don't see how you'd measure things accurately without more equipment.
