fred d
I currently have a 60 gallon compressor that belong to my father. It is over 50 years old. I had to replace the tank approximately 15 years ago. My father replace the electric motor approximately 40 years ago. It is a 5hp 220v motor.
A couple of years ago when I got a 80gal IR compressor in a storage unit I bought. I have no idea what (if anything) is wrong with. It looks brand new. I have not tried to fire it up, or checked it out at all because I have a good compressor.
I was going to use the IR tank on the set up that I currently have. 5hp motor that my father bought 40 years ago is probably twice the size of the 5hp that came on the IR unit.
A couple of weeks ago I unbolted the compressor and motor from the IR tank and unbolted the compressor and motor from my current setup. When I bolted them on the IR tank the pressure control switch was in the way of where the belt runs so I could not use it that way, so I just re-assembled both units.
There really is nothing wrong with my current setup, I just would like to have the newer tank and the larger capacity
The way I see it I have two options.
Sell IR unit and probably make a couple hundred bucks.
Or cut the mounting plate off the IR tank, rotate it 180 degrees and re-weld it.
I would not be welding on the tank, just on the mounting plate.
When I replaced the tank15 years ago, I paid more for the used tank than the whole IR unit
Thoughts? Suggestions?
