What to do with Corded Drill?
winlinmac
USA
As I make way for an upgrade in the near future, perhaps a Milwaukee Cordless Tool Set, what are some uses for my Dewalt 3/8" Drive Corded Drill? Would there be a way to permanently affix it on a workbench to drill at perfect angles (perpendicular to a horizontal surface)? What would you recommend? Thanks
zkling
They recently came out with a real spiffy tool called a drill press. Allows holes to be drilled at a pretty precise 90° or even other specified angles. I'd recommend one of those. Might not be in stores yet, pretty new, just saw it on this here computor box last week.
W
winlinmac
USA
Is there a way to set up a Corded Drill like a Drill Press? Would have been great if an adapter existed, because I don't know what the resale value on these general homeowner's tools go for. Its a $60 drill with warranty still valid for another 2 years (plus 2-year extended warranty via third party)
stonesfan68
Houston, TX
You'll find a use for that corded drill. I used a corded drill to polish my car's headlights. The batteries on my cordless Milwaukee just wouldn't keep up with the demand.
FigureItOut
Bentonville AR
There are many, many "drill press" jigs and stands of varying degrees of quality and effectiveness. None that I know of will match the results of a drill press. What are you doing with it?
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
Davefr
OR
Use it when your cordless batteries are dead
Use it when your cordless batteries will no longer take a charge
Use it when your cordless batteries can't complete the task without needed a mid project recharge.
Use it when your cordless tool battery are EOL and it'll cost you bundle to replace the entire cordless platform or cost you a bundle to replace battery sets.
MikeF2316
Thornhill, ON
I would suggest you keep it. You will find yourself using it occasionally in the future. I still have my first corded drill, which I've had since before there were cordless drills. Every once in a while I'll bring it out.
vintage nut
west coast of canada
My normal rule is to use my DeWalt 20v max cordless stuff, unless I have heavy drilling to do. If I'm doing holes over 3/8" (that can't be done on the drill press or mill) I'm getting my corded 1/2" Milwaukee. For holes over 1/2" it's a corded T handle. Hole saws are another one I'll use corded for too.
Also if you do restorations and want to use wire wheels smaller than an angle grinder, corded drills are great for that. Gets in tight places really well. I usually keep a few old flea market drills around, killed a couple wire wheeling. Doesn't hurt much when you paid 1-5 dollars for it.
Sent from my MotoG3 using Tapatalk
PelicanPines
If I have to crawl under something and spend TIME there drilling/hammerdrilling etc... the last thing I want is to crawl out to get the third battery because the first two I dragged in are drained.
Speaking of hammer drills... just went out and got a new ridgid corded to replace an old craftsman that I couldn't bother rebuilding... again.
lectricity... wonderful thing
Jim C.
I'd just keep the corded drill and continue to use it on hand held projects where you need some extra (and continual) power. Then I'd get a bench top drill press. The results will be better than any of those corded drill mounted jigs.
Jim C.
haha! I just had something like that happen to me last week, working on a deck project. After I managed to squeeze under the deck on my belly all the way in to the farthest corner I pulled the trigger on my cordless Makita, only to discover the battery had died. A quarter of an hour later I was back under again with the other cordless Makita.
So either keep a couple spare batteries handy, or hang onto the corded model.
Or you can just mail it to me for proper disposal. (Unless it says "Black and Decker" on it somewhere, in which case the proper storage place is the nearest trash can.)
jumbojak
Surry, VA
Keep it and use it when the perfect opportunity arises. Like stonesfan said, they're perfect for polishing headlights and other tasks where endurance is more important than portability.
speed bump
Butte Montana
I gave all of my little corded drills away to family members who needed a drill occasionally. Other than spinning mixer paddles, long bits where I need clearance, or big hole saws I almost never use a corded drill.
W
winlinmac
USA
I might as well cling on to the 3/8" Drive Black and Decker Cordless Drill I currently use every so often as well. :)
vintage nut
I think it all depends what you're doing. For light duty work a good cordless makes corded almost useless. For heavy fabrication a cordless is absolutely worthless
d.mcfarland
Western PA
This is hilarious!
On a related note we really need to limit what this person posts. We've AGAIN hit an all time low on intelligent posts by the OP.
rodm1
Keep it you will need it when the batteries fail you.
crackit
North of Java
+1 My corded drills get a lot of use. I don't like dealing with dead batteries.
