what to fill void next to support beam
joe121
orland park, illinois
Hi, my sons 3 car garage has some rotten brick molding on the vertical support beams between the bays. I am going to treat the beams with wood rot restorer, but there is avoid in the concrete next to the beam wherethe brick molding was. My question is what to fill that void with to keep future water out? thanks,joe
Kaizen
New England
So they poured the concrete around the end of the mounding? Concrete patch should be fine. PVC trim for replacement molding
J
joe121
Thanks for your response. Problem just changed to worse. Found the bottom of 4x6 post all rotted under concrete so we will have to replace both posts. thanks,joe
