What to get from snap-on?
Dj.SammyOaks
Wisconsin
Yes i know, its another one of those threads again, if you dont like it then dont read it. ANYWAYS, im in the ford asset program and have my awesome student discount that im definitely taking advantage of. Im mostly a matco guy because hes the most reliable dealer at work but matco doesn't always cut it. So what are some must haves from SO that matco just wont do? I already got a ratchet in every drive size from matco but im considering maybe a new 1/4 dual 80? I already plan on getting the flare nut wrench set and a set of FD+ wrenches. But what else are some SO musts? I dont need any extensions or swivels.
On a side note, I am also looking for a good work light. I dont want any that are like a 'stick'. just like a magnetic swivel led w. good battery life or rechargeable.
Thanks in advance! :beer:
wild cowboy
Birmingham
Torx bits are one of the very few things where there is not a much less costly but equally good tool from another maker, and Snap-On is justified.
I also like the $39.95 Snap-On LED work light at Costco.
bulletpruf
San Antonio
How about a long (24") 1/2" drive flex head locking ratchet? Don't think Matco sells one. Not sure on new price, but a nice used one still goes for $200 or so.
2oolhound
BC Canada
Pullers, bearing splitters, hand impact driver (only $65 for the tool only plus your discount), ratcheting screwdriver.
chipper
Williamsburg, va
I love all the dual 80's but I have big hands and the 1/4 feels really small in my hands I thought it would be my go to 1/4 but instead its hardly used...if I was starting out I would buy all the so screw drivers I could afford and then every drive in sockets and whatever you do and however long you have the step DO NOT miss out on the fd+
92integra
50% off hardline... comming from a guy about to place a big order.... i would tell you to grab at least the 3/8ths techangle and i agree about the torx sockets and flare nut wrenchs while u have the discount you might as well grab the flare nut crow feet as they will kick some *** if you ever do a power steering rack....... i dont have any other top notch ratchets and dont see the need since i have a few dual 80s / 72s ..... i love the fcf72 with flare nut crow foot for steering racks.... 1/4" rachets from so are bomb IMHO. i'm personally looking to get a coolent pressue tester from SO even tho i know its rebranded if ever have an issue with it warrenty is easy...... if u want 1/4" crome swivels just get the ones u need because even at 50'% off those things a pricey (I have gear wrench that i got for 30 bucks and am very happy with them besides the 10mm wich is more like a semi deep then a shallow)................................... impact swivel sockets go with matco if you can get the discount, even if a rep didnt come to your school you should be able to sign up online with them. GOOD LUCK! CHOOSE WISELY
Givl Reggin
Hawaii, USA
Dual 80 3/8 ratchet
Flare wrenches
Ratcheting screwdriver
Screwdriver set
Flank drive plus wrenches, 7mm - 24mm & 3/8" - 3/4" -- SOEXRM wrenches are one of my favorites. Flank drive plus open end and a 15° offset and reversible ratcheting box end--hard to beat.
1/4" Drive flex (swivel) sockets, 4mm - 14mm & 5/32" - 9/16" -- Snap-on flex sockets will flex further and give you more angle to work with before binding. You almost have to have a Snap-on flex socket at 90 degrees before it will bind. Having a flex socket that doesn't flex far enough defeats the whole purpose of having a flex socket in the first place.
Sometimes it's far better to have one expensive tool that works well instead of a whole set of tools that don't work. I'd suggest getting the sizes you need even if it's just a handful. They are far superior to anything else available.
devoncoolman
quakertown pa
Fd+ wrenches, snap-on's puller sets are some of the best on the market including the slide hammer set. Open end line wrenches are awsome. Stubby wrenches as well.
SASORacing
Utah
Check out the butane soldering gun kit, very nice!
Also the ratcheting wrenches, flank drive plus, reversible. Nice wrenches!
What do you need?
Wakefield
Arlington VA (but would like to get out to country
Specialties such as the S6160 that looks like a 1/2" drive extension but where the male end belongs there is a 12 mm. 12 point socket opening -might be better at reaching into a recessed hole than a regular 1/2"drive socket on a normal extension because it is skinnier-and it is probably stronger than using 3/8" drive stuff which would be as skinny.
Double jointed spark plug getter like S9721A (that one is for 5/8" plug)
the little 1/4" and/or 3/8" drive Universal sockets
when the money's a little tight there are Wright and S*K wrenches and sockets
Six Point Snap On combination wrenches? (I wish they had the grippy FD+ open end)
beatcad
NOVA
flank drive wrenches are nice. i dont have them, but i've used 'em and want 'em.
if you can get 'en cheap i love my snap on torque wrenches.
on is foot lbs and one is inch lbs.
depending on what you're gonna work on you may never need an inch lb torque wrench, but you might.
its been 15-20 years since i bought mine but i think its was just under $150 for the inch lb and around $250 for the foot lb.
if you can get one or the other for close to half that i'd say do it.
D
Dj.SammyOaks
Wisconsin
I always see people raving about those ratcheting screwdrivers but i just dont see when they would be so amazing? i have a bit driver and it works great for everything, when would i use the ratcheting screwdriver?
JoeMA
PA
I would love to get a BJP1 ball joint press for half off.
beatcad
NOVA
oh, yeah. those are great.
handy as hell.
i mosty use them for car int trim panels but i use mine for a bunch of stuff in the garage non car related
Jarhead0408
Who knows?
Yeah they do.
CFR248LFTG is the green handled one. I don't know how it compares vs. the Snappy version, but I believe the profile is thinner.
I have one. Freaking awesome ratchet. Doesn't flex at all that I've seen. Since buying it I've retired my 1/2 breaker bars.
pi_guy
N/A
The 1/4 inch swivels are my go to sockets.
I use my mid length 1/4 sockets on shock adjusting nuts gives me a better feel than std or deep length.
The others ones I have been very happy with are 3/8 deep swivels had metric for years and std are on my want list.
In wrenches I have mostly used short in combination, ratchet and box style, recently have added midget to the lot.
But the bulk of my work is 1/2 or 7/16 bolt heads and 1/4 or 5/16 aircraft nuts.
But any Snap -on hand tool is the way to go.
92integra
word of warning if you dont think you'll use the ratcheting screwdriver DONT BUY IT. i didnt think i would use mine but every one of GJ love's theres so i have to have it and see what all the fuss is about... it sit's like a worthless 60 dollar bill in my tool cart used once.... sure mabye i could use it on interior but my cordless ratchet and hex impact can do that same job as it twice as fast.
D
Dj.SammyOaks
Wisconsin
see thats how i feel what would happen if i actually got one.
pi_guy
N/A
I do a fair amount of electronics work and avoid the use of power stuff, so I find the ratcheting driver worthwhile. Plus we do a bunch of fasteners into nutcerts and to much torque rips them out.
I just told my Snap-on guy to try and find the limited edition Red and white one.
purplezr2
Central MN
Yeah they do.
This ratchet is one of the thinks that matco does better than Snap-On in my opinion. I have had both and still have my matco
Exceller8
Banning, CA
The short gasket scraper is awesome! I use it for all kinds of things around the shop. Everything except gaskets... :D
wagzilla
Arizona
I have two of them they are great! And they don,t get hot
James
JAKE-THE-TOOL-MAN
Bremerton, WA
My favorite items from snap on are their wrenches, screwdrivers, and ratchets. I have a set of their Torx bits and Hex bits and they are probably the best on the market but I also have a master set from Cornwell which are rebranded Taiwan that get the job done just as well. For a light would look at getting a stream light and a magnetic swivel base for it. Very handy and bright. I don't care much for snap ons lights.
skylinegtr20
I have this set, its fantastic. Very handy that the pieces "clip in" making it easier to assemble.
+1 for the matco 24" locking swivel ratchet, I sold my Snappy after using it.
+1 for the 1/4 swivel sockets, I have the impact version and I use them alot with my air ratchet or small 12v impact. I would also recommend Matco for these though in any size (1/4, 3/8 or 1/2) as I like feel better than SO.
Here is the list I would buy to get going with the 50% off discount.
- Snappy Dual80 or Matco 88 tooth Ratchets
1/4 - get the long 6 1/2" w/ swivel
3/8 - long handle w/swivel
1/2 - 24" swivel/locking
- Matco 1/4 & 3/8 metric impact swivel socket sets
- Matco 1/2, 3/8 and 1/4 universal impact swivels (for all other swiveling needs)
- Snap On 3/8 techangle torque wrench
- Snap On Flank Drive+ metric wrenches (8-19, 21, 22 & 24mm)
- Snap On Flare Nut Crowfeet metric (10-19mm)
- Snap On Metric Flare Nut Wrenches
- Snap On, Matco or Mac Knurled extension set
- Snap On Torx bits w/tamperproof
- Snap On Hex bits
- Snap On Dead Blow hammers (16oz & 32 oz or bigger)
- Mac Antivibe hammers
And if you really want to get baller. Add a set of extra long flank drive+ wrenches for alignments, front end puller set, ball joint removal set and a set of Snappy 4 angle wrenches they are pricey but worth their weight in gold!
JAKE-THE-TOOL-MAN
Bremerton, WA
I have used the 1/4 chrome swivel sockets and they are fantastic, I just can't justify the almost $500 price tag. I'm not sure what the discount would do for the price but they definitely are the nicest.
JAKE-THE-TOOL-MAN
Bremerton, WA
I always wonder why people love them so much too? I have the stubby and regular hard handle version and have never used them. I prefer my electric screw guns. Much faster.
