I have an old craftsman air compressor which still can pump up but noisy as heck.
I thought I’d try to quiet it down a bit with a muffler as it had just as a foam intake filter. (It didn’t work). I attempted to seal the gap between the muffler pipe and compressor head with some high temp Rtv but I screwed up and turned it on before it completely cured and sucked some into the compressor. @#&$#! So pulled the head off and scraped a few bits off the reed valves and compressor is back to old noisy self. The head is actually a two piece head, one chamber on bottom, middle plate, and top chamber with a thin rubber like gaskets apparently integral to one side which mates against an opposing flat surface. I checked for leaks after with soapy water and have a spot it bubbles. I was wondering if there was something which might be able to be used as sealant? It’s not too bad of a leak, working ok for its age and I didnt want to make it worse trying something which screws up the existing rubber seals - so was wondering if anyone has experience with something which would work or I should just let it be.
thanks for the advice!
I thought I’d try to quiet it down a bit with a muffler as it had just as a foam intake filter. (It didn’t work). I attempted to seal the gap between the muffler pipe and compressor head with some high temp Rtv but I screwed up and turned it on before it completely cured and sucked some into the compressor. @#&$#! So pulled the head off and scraped a few bits off the reed valves and compressor is back to old noisy self. The head is actually a two piece head, one chamber on bottom, middle plate, and top chamber with a thin rubber like gaskets apparently integral to one side which mates against an opposing flat surface. I checked for leaks after with soapy water and have a spot it bubbles. I was wondering if there was something which might be able to be used as sealant? It’s not too bad of a leak, working ok for its age and I didnt want to make it worse trying something which screws up the existing rubber seals - so was wondering if anyone has experience with something which would work or I should just let it be. thanks for the advice!
