What tool, Job or Task Intimdates you?
Labradorian
Pembroke, ON
What tool, Job or Task Intimidates you?
not sure if this sort of topic has been discussed or not or even if anyone is willing to admit to such a thing.
we all use all sorts of tools and gadgets, etc and I'm sure there are tools or tasks out there that some people find intimidating to use.
I myself was never comfortable using a table saw. Not sure why .
how about it? What jobs, tools or tasks you do that you just never get comfortable doing or using.
cheers
:canada2:
scouting
WY, USA
Easy-outs, I can't even stand looking at them in the box.
Edit: I have good luck with them, but taps smaller than 1/4" do intimidate me.
StingRay
Saskatoon,SK. Canada
Anything on a tall shaky ladder. Heights don't really bother me if I feel secure. Shaky stuff or really steep tall stuff I don't feel secure.
rieferman
Collegeville PA (30 min west of Philly)
Although I think I could do it at this stage of my learning curve, I've always avoided soldering copper plumbing pipes because I was intimidated to try it. In fact, I think this weekend I'll give it a try on a few scrap pieces to prove to myself that I can do it.
Drywall finishing still intimidates me after doing a fair amount of it, and getting pretty decent at it.
On the other hand, routers, tables saws, circular saw, miter saws, chain saws... I feel very comfortable with all those.
edit: 1+ to the shaky heights noted above
48RON54
Inland Empire, CA
The task that intimidates me the most is the front brakes on my 03 dodge ram. I'm almost ashamed to admit it, but they kick my *** every single time. I bet I do them twice a year and it never gets any easier. If someone walked up and saw me replacing those pads they would think it was my first day with a wrench. I do a good amount of wrenching but the second I hear those pads start squeeking I start to dread the work I have ahead of me.
Ruger_556
How many miles are you putting on that thing that it needs brakes twice a year? :wtf:
48RON54
Inland Empire, CA
Maybe 20k.... I always have issues with those brakes, hence why they intimidate me. Maybe it is once a year and it just feels more often because of how much I hate them? lol
Another one is getting under an old car with a grinder with a wire cup to clean off all the **** under it. That is **** work and the position you are in with the grinder leaves very little useful muscles for when the grinder inevitably kicks back at you. Everytime i do that I feel like I'm in my coffin.
Raven GT
The Netherlands
I'm always VERY carefull when using the tablesaw, as I know a few 8 and 9 fingered carpenters, its doesn't freak me out or anything, but after seeing the end results on someone that had been a carpenter for over 30 years when it happened...... :shocking: you start to respect what it CAN do.
Industrial sized lathes, as in 3 meters plus between centers, do NOT stop for anything, I don't mind working on a lathe, as long as everyone else stays away.
Had a guy on a previous job that tried squeezing his fat *** between me and the tooling cabinet, nearly pushing me in a running lathe. As in my chest was
4 inches from the workpiece.
Servicing the Shredders and Balers we build at work, doesn't really intimidate me, again it's more the idiots that walk/ride around 'm that make me cautious.
When we test the finished shredders, the guys will usually look for the biggest piece of wood they can find, and toss up into the feed end.
Ever see a foot wide by 5 inches thick piece of beam of about 4 feet long get turned into dust and small chips in under 5 seconds ??
A lot of times at customers I see al of the safety features disconnected or bridged, including emergency stops and safety guard lockouts removed.
Not really a reassuring thing when your working INSIDE something that compacts stuff with 180 tons of pressure :eek7:
Several people a year die that way, usually trying to kick something that's stuck in the chute down into the baler / shredder, losing their grip/balance and going in after it. Off course they did leave the system running when doing that, cause we don,t wanna slow down production do we ? :thumbup:
2 Years ago I was doing some work at a plant that was building a system expansion at the same time, so there's a load of guys from another company using magnet drills (the big ones) to drill holes in the structural steel supports and roof beams of the Huge metal building, to bolt some new conveyors and catwalks to.
There where only a few points in that place where you had power, so its extension cords galore, and all of a sudden it's a mighty loud racket, and my welder stops working.
Turns out the plants safety manager :shocking: with al of his 25ish years of wisdom, thought al the extension cords coming from the central power hub, where a tripping hazard, so he just unplugged them al :bounce:
Just imagine close to 25 magnet drills falling from 10 to 30 meters, and bouncing of machines and concrete below. luckily no one below was hurt.
About 5 minutes later, his feelings where though :lol_hitti, cause there's about 70 to 80 pissed off guys ready to....... express there feelings ... :bubbrubb:
teamextreme
Lakewood, CO
Wow, I get 70k to 80k out of the brakes on my 05 (on my 3rd front set). Is it the process of getting the pads in the calipers that is kicking your ***? I had issues everytime I've changed mine until the last time. I finally decided there must be an easier way and did some internet searching and realized I've been doing it wrong. The caliper consists of 2 pieces, unlike all the other dozens of brake jobs I've done on other vehicles, and you have to take the caliper apart to get the pads in easily. Otherwise you bend up the metal tabs which happened to me all the time before discovering this.
Back on topic; are we talking intimidation due to fear, ie; chainsaw, table saw, or due to difficulty? The task that intimidates me, due to difficulty, is setting up differential gears. Got all the tools, tried it once and had to have a mechanic friend help me get it right cause it whined like a mofo when I was done. So now I'm reluctant to try that again.
fsae0607
San Fernando Valley, CA
I would say going into the crawlspace of a house. I can do the attic just fine, but the crawlspace just scares me. There's no room to roll over for me, it's dark and eerie and there's black widows all in the corners. Needless to say I always try to run new circuits in my house through the attic!
MDSPHOTO
Oz
Anything that requires me to be up on an extension ladder. I don't fear heights I fear the potential of sudden deceleration trauma.
48RON54
Inland Empire, CA
Hmmmm, i never thought about an internet search....I just figured they were a PITA, end of story. I'll consult the google machine to see if perhaps I'm doing something wrong (or at least not the easy way). Thanks.
ADSR
Timing belts. I sweat bullets taking the old one off and listening for the gear to move.
Vegaman_Dan
Pacific, WA
Laundry.
Whites, colors, solids, stripes, delicates, permanent press, etc. I just toss it all into one pile and call it good. So many options and choices.
Hinez Wengler
Dusseldorf
Cutting the nails on my feets and riding on skates :shocking:. Anything else I can deel with.I have to sit only to rub my knee.:(
My hinges are wore out.:eek:
Premium08
Littleton, NC
Working under my cars in my rock driveway, miss living at home and having that garage. ;)
Sent from my SCH-I535 using Tapatalk
ARCTIC_RAGTOP
Yellowknife, NWT
Out of all my saws (chain, miter, table, reciprocating, jig, band, hand, hack, serpentine, circular), the table saw still intimidates me. When that ******* gets fired up it sounds like a harrier jet! I know the goal is to cut the wood and not myself, and I take safety measures to ensure successful cuts occur, but it still intimidates me a little. I would much rather use the circular saw.
RivennHewn
PNW
Seems everything I work with has a moving or spinning cutting blade on it.
The one I have the most respect for is the shaper.
Even with the guard and power feeder, I'm always a little leary of that massive 4" blade spinning at high speed.
shawnspeed
Dad was a wood pattern maker, and I have a healthy respect for all power tools, and treat them with respect...the one tool that scares the **** outta me was a big shaper they had in the old model shops...some were big enough the guys would bondo 18&24 inch angles to them to have something to push the wood blocks they were pushing through the shaper..I was often permitted to tour the shops and one had a large repair to the block wall and ceiling where something came out of the shaper..I think dad said it knocked the operator out cold...after it had done the damage to the building...
jim1987
Brake lines and drums. Won't touch them. If I mess up a starter or something else stupid, its just an expensive fix. Messing up brakes... ya. No Buenos.
Wamerjamer
That's me,we were painting a barn roof one time,and I was so woobbly that I voluntereed to be the ladder " guy",bringing paint and hardware to the guys on the roof.The side of the roof that concerned me was the front, with a concrete,
"Landing".The backside at least was grass.I stayed on the ladder.
Randy
jaymz1967
Northern Illinois
I'm with LORDDiESEL on this one.Timing chain or belt on an overhead cam engine.I check and re-check the timing marks and all that a dozen times and my heart is still in my throat the first time I start the car.
blackhawkdriver
Tennessee
Anything electrical. When I was a kid I accidentally stuck a wire coat hangar into an empty light socket shocked the **** outta myself. needless to say It left an impression.
coljar
Belpre, Ohio
I guess I haven't found any tool or task that intimidates me, but there are a lot of ones I don't like doing, especially as I get older. I never liked doing my taxes, concrete, and drywall in that order.
ADSR
I cringe just reading this!:eek:
Joe69
Muncie, Indiana
Roofing my house. I re-roofed my last one, no problem, but it was fairly flat. I've been on the roof of my current house, and I'll never do that again. It's about a 12-10 pitch. It was all I could do to stay on it.
Joe
EricP
Alabama
Dad was a wood pattern maker, and I have a healthy respect for all power tools, and treat them with respect...the one tool that scares the **** outta me was a big shaper ...
I spin an 8" diameter cutterhead on mine and it is damn scary. To make matters worse I'm machining small parts with it. The only sane way of doing it is a fixture to hold the pieces and guards surrounding the cutterhead in it's entirety.
In actuality tablesaws cause more woodshop accidents than anything else, kickbacks and cut off fingers. A buddy of mine owns a 14" saw that a guy used to commit suicide with. He raised the blade a full 6" out of the table and purposely fell into it with his chest.
RedneckWelder
The Ghetto Kingdom of Methlandia
I don't like tablesaws, circular saws, or chainsaws. Honestly all three intimidate me. I'll use them but don't like them. Don't mind bandsaws (horizontal or portaband), or miter saws, or reciprocating saws. that's pretty much all the saws I deal with.
Job- stuff involving heights. I do not like to be up in the air. I HATE roofing work, mainly due to never feeling like I have secure footing on the slope.
I also don't really care to be under something suspended, either.
Task- doing complex, critical tasks the first time always intimidates me. Once I'm used to it it's a piece of cake then.
WVBrady
WV
Do you turn it over slowly, by hand?
CJM8515
I hate ladders and heights. Anything over 15ft high I get a bad feeling in my stomach and feel uneasy being up that high.
