What tool to use
WTXTundra
Odessa
So I’ve got a sight glass I need to remove. It’s maybe an inch wide with maybe 1/8 risers from the face. I’m waiting to hear back from the manufacturer to see what special tool the use to unscrew this but maybe you guys got a better idea.
Suggestions?
Steve_P
Lisle also makes a few antenna sockets. The issue is that they can be kinda fragile. I have a Sunex set, that they apparently don't make anymore, and ruined one of them on a similar task.
Suggestions?
I've been looking at the pic, and trying to determine what you are trying to do. Does that whitish plate with the 3 holes in it need to rotate? Or each of those three holes rotate?
If the large whitish thing rotates, a strap wrench looks like a winner, especially as diameter gets up to 8", as does a big pin wrench, assuming that is about a 3" diameter. With no sense of scale, I'm lost here.
Beerhippie
Far NE Oregon
Pretty sure the little bevels are what need to come out to replace the sight glasses--note one is missing.
Thanks, Was confused by the orientation, most sight glasses of that diameter that I see are vertical. Diameter of the big plug is what I expected for horizontal, which that pipe seems to be with sky and gravel orienting me.
AEAdam
SE PA
Google “hook spanner”. Lots of hardware like this on old machines.
(lower right)
Hint, we usually tap them with a steel hammer.
There’s a set of 4 spanners lower right. Top 2 are hook spanners, bottom 2 are pin spanners. The weird spanner adjacent to my spare 3/4” combination wrench is a face spanner.
Need to know their names to ensure you are getting what you need.
