What type bit do I need?
econoaddict
Oregon
I am drawing a blank..........
I need to make 3/8" diameter holes, 1/8" deep in aluminum.
Not going all the way through, they must have a flat bottom.
What is the bit called I need?
jjjrmx5
Cincinnati, OH
You doing this with a hand drill, drill press, 5 axis mill, water cooled CNC mill, metal lathe/drill machine or what??
Big differences.
lwlobo
Colorado Springs, CO
I think you're looking for an end mill.
I strongly suggest not doing this by hand, a drill press is minimum and mill is reccomended.
metaleltr
Western Ohio
iff all you have is a hand drill you may be able to accomplish this with a forestner bit, it wont be easy and may destroy the bit, use lots of wd 40
kenburkholz
The bit you need, is an end mill, just be sure it is a center cutting bit. Also very important is a very secure hold down. Ken.
Givl Reggin
Hawaii, USA
Depending on the accuracy you need, I think the steps are after you do the lay out are;
1) Center Punch
2) Center Drill
3) Twist Drill
4) End Mill
5) Reamer
larry_g
oregon
Assuming you have no pilot hole then a center cutting end mill. If you have a through hole then you may be thinking of a spot facing tool or a counter bore.
I would give Mr Riggin a bye on this as I think he miss read the question..
lg
no neat sig line
augustus
Columbus, OH
I use my forstner bits all the time, on wood, at least with my set you don't an absolutely flat bottom, they leave a little cone from the pilot.
E
econoaddict
Oregon
Thanks for all the input.
I am thinking the bullet bits will do exactly what I am looking for on this project.
A_Pmech
IL
Without a milling machine or sturdy drill press, you need a way to establish location first. If there's a thru hole in the center you can use a piloted spot facer with the appropriate pilot.
Without a thru hole to guide a flat bottomed tool, I would start the hole with a 3/8" 135 degree twist drill about .05" deep and finish it with a 3/8" end cutting endmill or a 3/8" flat bottomed drill:
