What Type of Clamp?
Bob55
I've never seen a C-clamp like this and could use
help to explain it's function. Thanks
Bob55
It opens to 2-1/4" between centers and frame measures 5-1/2".
Milton Shaw
With those points it would have to be some kind of alignment tool. Those points would not be good for any kind of clamping under pressure.
nadogail
Coronado, CA
IMHO, it looks like something made from a clamp to do a job. Maybe a home made tool to rivet brake linings to shoes, before bonded linings became standard in the 1950's.
DD T/A
North of ▼PL∇MB▼
People from the new world who drive new cars look at people like me and ask, "why does your old car leak so much?"
I answer back, "They ain't leaks, that's perfectly normal."
Farmer J.
UK, Cornwall/Hertfordshire.
Here in the 'Old World' we still make brand new cars that leak the same as the old ones!
That spring leaf separator looks like a useful tool, I may make one up from a G clamp to lubricate springs around here. Leaf springs work a lot better when lubricated it reduces the friction between the leaves, but dirt and grit can stick to the lubricant. I have a friend who used to slather grease on the leaves of his Land Rover springs when assembling them, then wrap a canvas bandage around the spring to keep the dirt out. His vehicle was more comfortable to ride in than most.
toolchaser
Greenville, GA
I know some of the brass era cars had wrapped leaf springs to help with lubrication, but most abandoned because as the cover failed it held in moisture & grit
Farmer J.
Yea, that's exactly what used to happen with my friend's leaf sprung Land Rover. He is so OCD that he used to take them off, disassemble and clean them, and re grease and wrap them again.. Eventually he got sick of doing it and bought a bought a new one with coil springs.:willy_nil
Milton Shaw
I had a 56 Ford that had wax soaked canvas squeak silencers in the rear leaf springs. I had to replace them a couple of times and could have used that tool then. Didn't know they made one. I just used an old screwdriver as a wedge. Those were a lot better and longer lasting than just grease.
I've seen a different version of that tool on another site, never one as simple as that.
https://scontent-sjc3-1.**.fbcdn.net/v/t1.0-9/38635133_10214989200876377_8655534505139896320_n.jpg?_nc_cat=106&ccb=2&_nc_sid=825194&_nc_ohc=i99Ya458GVYAX8HanZ1&_nc_ht=scontent-sjc3-1.**&oh=cd3262c221c5368c87ca4f0bf04d223a&oe=5FCD9895
https://scontent-sjc3-1.**.fbcdn.net/v/t1.0-0/s526x296/38600323_661671257529156_4742002408589099008_n.jpg?_nc_cat=101&ccb=2&_nc_sid=dbeb18&_nc_ohc=gytte2t6YQ8AX8i4Ue2&_nc_ht=scontent-sjc3-1.**&tp=7&oh=2027cd9a7c8925f11feb0ca0ec75c73f&oe=5FCEC3F3
crguy
SW Washington
Leaf spring spreaders have been around forever. Some even have grease cups built right into them.
Here is a variation
steaks&anvils
Colorado
I have one like this, made by Williams. I have no use for it. I bought it for $0.50 at the habitat re-store because it looked cool.
mikegt4
sw ohio
That was common from the factory on many 50's and earlier cars, they called them "gaiters".
