csp
Background:
The property my home is on had electrical service (not turned on though) on it when I bought it which was huge. I believe that the wire coming from the transformer into the main meter and panel (located on a power pole) was either 1/0 or 2/0 aluminum. I can't remember which. The panel it fed was rated to 400 amp and the EMT conduit between the meter and weatherhead was 3.5". Coming out of this panel was the same 1/0 or 2/0 wire which went underground to an existing pole barn about 25 feet away. Unfortunately the service entrance panel and meter were in bad shape and had to be replaced when I started to build my home and needed the power to be turned on. I owned the property for six years prior and never had the power company turn it on.
The replacement meter/panel is a 200 amp combined unit which is a feed thru panel. The feed thru portion then goes to the house. The end of the wire that previously went to the pole barn was buried so that I didn't have to update the barn electrical as part of my permit for the house. This brings us to my current problem.
The feed thru panel has room for six to eight breakers and I want to add a breaker to feed the pole barn. The wire which is underground is too large to attach to a breaker, so I need to reduce it down to a size which will work on a 100 amp breaker. I'm just not sure what type of connector to use and what type of enclosure it might require.
Everything in the pole barn has been updated to code and a permit is in order.
Anybody have a suggestion?
