What type of roller? Urethane clear coat
gcretro
Home
Hello,
A week ago, in my garage I did epoxyshield epoxy and then later put the supercoat water based (2 part) urethane clear-coat with anti-slip. I had used a polyester 3/8 nap roller when I did the clear. It seemed to do fine.
But the surface is quite slippery (anti-slip had settled to the bottom of the can despite low-speed stirring each time before filling paint tray).
So I plan to do a second coat of the same clear. I have lightly sanded the surface.
Instructions with the clear said to use 3/8 nap roller. I was wondering if I should still use the same kind for the second coat?
My main goal of this second coat is to get more of the anti-slip into the final coat to reduce slipperiness.
LegacyIndustrial
deerfield, IL
Only certain types of anti-skid can be mixed in.
Aluminum-Oxide, Ottawa Sand, etc... have to be broadcasted and then backrolled. They are too heavy to mix and roll.
HDGrip-Soft-Skid, our product, can be mixed in, poured into a paint-tray and rolled out, without broadcasting.
Identify your agent, then use the appropriate method.
Also... woven dralon is tops for the roller. Always get the best you can.
Good luck!
