What Type oil do you use in Ratchets?
zktk01
KY
I have tried a few different lubes in my Ratchets. I put Evinrude marine Grease in one very quite now. I have used 3in1 oil with PTFE in some, I like that best so far, I have also used Rem Oil.
I usually clean them with CLP, I just wanted to see what everyone else used.
jdlong
Kaukauna Wisconsin
I too use synthetic motor oil because in freezing temperatures, the stuff doesn't turn to molasses. The pawls on fine tooth ratchets do not fully engage with molasses.
mudflap
cincinnati,ohio
Pu**y Juice...It lubricates...and makes my ratchet smell good.....:rocker: Then if u get caught sniffing your ratchet...just tell your co workers your nose was itching, and your hands are greasy...But u can only use that one so much... I know....
RainCoat
Pacific NW
I have used white lithium in the past that seemed to work well and provide a smooth action. Now I just let the snap on man lube them up. I love clp for guns though.
Z
zktk01
KY
:lol: Your Toolbox must smell like fisherman's wharf.
gdocktor3
Connecticut
stercorarius
Eastern Washington
Super lube, but think I'm going to try Lubriplate SFGO Ultra 460 like I use on forcing screws as it is the stickiest gear oil I've come across. It may be too sticky for ratchets though.
Sent from my S60 using Tapatalk
Z
zktk01
KY
I just bought some Super Lube off the link on the youtube video
mudflap
cincinnati,ohio
Because its the same thing as asking "what type oil do you use in cars?"
Valvoline, or Castrol always..never Pennzoil, or Quaker Stare...those have too much parafin...will gum up your engine. Especially if you skip an oil change, and leave it in there too long.. And unless your vehicle started out with synthetic...don't switch to it..i know they say u can...but i got the inside scoop from our oil distributor...so there...lol
Wamsutta
Amarillo, Texas
Not exactly. Motor oil in cars are very similar except for the different viscosity you can choose. Lubricants for ratchets has a very broad spectrum because of the extreme differences ranging from oil to grease. And each type of lubricant will effect a ratchet differently.
On sealed ratchets, some lubricants will even cause the seals to swell up to the point that reassembly is impossible when reinstalling the seals. With high viscosity wheel bearing grease, the gear pawl will have a tough time engaging with the ratchet gear as evident by the absence of the familiar clicking sound.
And then, you'll have one single ratchet that works differently with different lubes. From my experience with trying different lubricants on different ratchets, my conclusion is that having a universal lubricant for all different types of ratchets doesn't always work best.
It's best to match the lubricant to the ratchet. And only by trial and error will you figure that out. I've already don't all the trial and error experiments with my ratchets, so I'm done with it. For example: I've got it figured out what works best for a Snap-on sealed ratchet and what works best for an unsealed MAC ratchet.
gdocktor3
Connecticut
:wtf: All I meant was everyone has their own particular brand and viscosity.
