What wire for 100A feeder?
I have a 150A main in the house and bought a 125A sub to install in my yet to be built detached shop. I'll be running radiant floor heat at some point in the shop as well as a lift and a 220V MIG plus the usual lights, power tools, etc.
The main is on the east wall of the basement, so I need to run wire through/along the first floor joists about 36' west and about 12' south to get out the back side of the house, then I've got a buried run of about 130' to the shop (the plan is to trench and drop in 1 1/2" conduit for the electric and another 1" conduit for a couple of CAT5 runs) to the west of the house.
The electrician who my contractor uses was throwing around a bunch of numbers & letters as he was sorting things out in his head while looking things over, but i wasn't around for what he settled on (I was having some rocks delivered and went to help the guy get them off of his trailer). The only thing that I've picked up on is #3 copper. I want to do the runs myself since I'm perfectly capable of handling the grunt work instead of paying him for that part, and I'll just have him make the connections. At one point he talked about using two different types (the letters) of wire, one for inside the other for outside with a box mounted on the outside of the house for the junction, but it sounds like he settled on using the same stuff and possibly just doing one straight run with it. Does the single run sound like a good idea, or would the junction box outside make more sense even if the same type of wire is being used the whole way? What type/types of wire should I be sourcing for this? Thanks. Attached pic is of my lot (yellow line) and the red box is about where the shop will sit.
