What would a good durable paint be?
catch22
Just wondering if anyone has any good ideas for painting the drywall in my garage. I want it to be durable and easy to wipe off as im planning on using it as a small machine shop and coolant and oil are probably going to splash on it.
Thanks Mike
Plombob
Tennessee
A good primer will make all the difference. I only use the Kilz Premium and the paint I put over it holds up for a decade or more. Don't have experience with coolant or oil though.
ddawg16
S. California
Ditto on the Killz....Killz II to be exact....it's a great primer for bare wood and drywall.
It was rated the highest by CU.
Behr from HD is a top performer for semi-gloss....but if your concerned with oil I would suggest high gloss....
Jack Olsen
Los Angeles
Use a semigloss paint for easier clean-up. A flat paint (like you'd use in your living room) is going to act like a chalkboard when you brush anything against it.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
If oil and coolant is going to periodically get splashed on it, then I would go with a high gloss paint. I have my walls painted gloss white and have even hit them with the water hose before and no damage to the drywall.
C
catch22
Thanks everyone for your input,I will go with the Killz II primer and an Exterior Semi-Gloss or Gloss paint to finish.
Thanks Mike:beer:
jake210
Florida
I would go with a good primer and a water based epoxy. It may be a little overkill but will last for ever.
