What would you do with this....
mowkep
Stow, Ohio
what are my options? Pretty rough shape
Junkman
Northeastern CT
Disassemble, then soak in rust remover. After it is cleaned of all rust, using firearm blueing, or a black oxide finish, reassemble, and call it a great find. Not all Snap On tools were chrome plated.
M
mowkep
Stow, Ohio
I'll have to see what the FIL left in the garage. I think there's some gun bluing and possibly rust remover
M
mowkep
Stow, Ohio
I got it apart. What an amazingly simple design. Gear looks good just dirty. I'll have to grab some rust remover. Evaporust? Where would I find it, hardware store?
Jason280
I've always used a fine wire wheel on a bench grinder, at least after a good soaking in carb cleaner.
EOC_Jason
Bentonville, AR
You can get evaporust at Tractor Supply cheapest usually...
Lowes carries some WD-40 soak and something that is similar...
You could also soak it in some vinegar or a molasses mix...
Or hit it with a wire wheel...
M
mowkep
Stow, Ohio
I got some of the Loctite naval jelly rust dissolver. Hopefully that will work and is safe
M
mowkep
Stow, Ohio
Just a little better after applying rust dissolver and soaking everything in engine degreaser. I'll have to get some bluing and finish it up.
B.S.A. (ret.)
Central Connecticut
A good start towards your goal. Try hitting it with a wire wheel as someone mentioned above, then some jeweler's rouge and a polishing wheel to really put a finish on it before bluing.
gungatim
west mich
Ditto.
I did that to a bunch of the old snap-on metric sockets 1/2" drive, with the silver finish (50's vintage I think).
wire wheeled them down, shot of brakeleen, then gun blue (I prefer the burchwood-casey paste type).
they have a great black finish now. worked so well I re-did some older rusty impact sockets and they look like new.
rsanter
visalia ca
Exactly what I was going to say...
Bob
M_George
Eastern Pa.
I would scrub it with WD40, Super Lube the internals and put it in my collection of old ratchets. The patina looks good the way it is for collectability.
M
mowkep
Stow, Ohio
I decided to give this to my nephew. He'll appreciate it more than me. I visited my son in Virginia and his fishing bug came back. I donated my 5 piece Craftsman pro mini pliers to him and my felo 5 piece screwdriver set to his Airman buddy
