What would you use a 46mm spanner for?
potato
thats only 1-13/16" kinda small.we use up to 2-7/8",or 73mm, here for oilfield equipment.
Lelandwelds
Central Texas
Windpower, lightpoles, and signage all use larger fasteners than that. You run the nut down by your favorite method and tighten with a striking wrench.
I would use it as wall art. It would be the only tool I ever polished.
jalind
Northern mid-west USA
IIRC, and I had one of these decades ago, the rear axle nut and engine gland nut are both 36mm, not 46mm. Nevertheless, they were a bear to remove and replace to proper torque. If the rear axle nut wasn't torqued down sufficiently, the lash in the splines would strip the splines out of the rear brake drum.
Correction:
The rear axle nut on the Type 2 (aka buses) from '64 onward were 46mm. I need to read more closely. AFAIK, all the beetles, Things, Ghias, Type 3, and buses '63 and older, etc. were 36mm.
46mm could be a size used on very large nuts holding large light poles and large bollards to their foundations. Some of the bolts and nuts I've seen on some of these have been rather large. I don't know what the common sizes are for them. Millwrights who work on the big stuff would have wrenches in this size class.
I have this 24" adjustable - it dwarfs the 12" and 10" - and I have a 50mm combination hanging on the same hook with it. They're about the same length.
John
bob15
Northeasten, CT
Apart from a hammer or door stop, what automotive jobs (or otherwise) uses a 46mm spanner or "wrench" as you Americanians might know it as?
Thanks!
What makes you think wrenches are only used in the auto repair field? Something that big (and bigger) can be seen & used in the oil industry, mining operations, refineries, factories, farm/construction/industrial equipment repair, etc
plinker
Northern Wi
Kesla log loaders (made in Finland) have their tie down nuts in 46mm hex size. Dont remember the stud size, likely 30mm.
Mr. T
Central PA
I’m gonna go out on a limb and say that if you don’t already know what you can use it on it’ll make a nice hammer or door stop...
As for me, I use one on Ermeto (DIN/EO) hydraulic fitting quite often.
Matt Irvine
Aussieland!
I used to use 46 heaps for gas refinery stuff, 1 1/8 studs. I’ve used it a few times in hydraulics as well. Industrial gearbox studs, are a few examples. 46 is the standard for M30 nuts , and a conversion for 1 13/16
A
AndySchlagzeuger
Melbourne Australia
I don't think that! :) Hence "Automotive repairs (or otherwise)" I mainly work on cars though.
:thumbup:
In any event, my chance to own the old spanner/wrench has now slipped away, but thanks for list of things it can be used for.
JeepinMike
I have bolts on the Unimogs I use a 46mm socket. The loader on my 406 uses a pair of bolts to hold it down.
jhelrey
MN
Why use a striking wrench vs an impact? I had to Google the striking wrench part.
Finky198
North East
Its like impacting lugs without checking them with a torque wrench or breaker bar ... sometimes impacts are not reliable and a striking wrench is a manual force that can be seen and felt... other times the socket is not deep enough for the stud so a wrench is required for the final tightening.
Randy Kegg
I have one. They don't get a lot of use in the automotive field, but there is one job where it is essential. When you are installing a new muffler on a 1972 or newer air cooled VW bus, there are two 46 mm nuts that must be tightened as part of the install. You need that open end wrench to do it. I bought it for that task alone and I have never used it for anything else.
Randy
CoryDH
VA
Not a 46, i know harley davidson dyna axle nuta are 32mm. Still a good size wrench
Sent from my LG-TP450 using Tapatalk
Jaysreal
Pittsburgh, PA, USA
As a Forklift/equipment tech, I have one very large wrench and it is a Proto 46 mm. I have used it exactly twice, both times for the kingpin nut on a JLG scissor lift.
Sent from my Nexus 6 using Tapatalk
