what's a good average torque setting?
tpolley
kansas city
what's a good average torque setting for general applications? does it depend on the size of the fastener? does it depend on the application? is there a "rule of thumb" that says tighten a 1/2 inch bolt to 100ft lbs or a 3/8 inch bolt should be tightend to 85ft lbs.
Moose-LandTran
The Brink of Insanity (England)
it varies massively by application and fastener concerned.
Most VW-Audi Group cars, Mercedes-Benz and BMWs run 110-120nm (~81-89lb/ft) for the wheel bolts.
I'm the only person at work who torques every single wheel nut/bolt..
T
tpolley
kansas city
Most VW-Audi Group cars, Mercedes-Benz and BMWs run 110nm (~81lb/ft) for the wheel bolts.
i'm referreing to non-automotive applications. say i want to bolt two pieces of steel together with 1/2 inch grade 5 bolts. that kinda stuff.
Moose-LandTran
That would depend entirely what you're doing then, for things like construction and gas/fluid piping they often compromise between high torque (therefore very tight) and not risking damage or warping something. It depends entirely on the application and situation. Torque will also vary by nut/bolt grade. There are no rules of thumb for torque in general, as far as i know.
Mike83
Wisconsin
Be advised that thread lubrication will have a drastic effect on the final tension in the bolt. A well lubricated bolt will take longer to click the wrench and may become overtightened. That is why turn of the nut method is more reliable for uniform tightening.
T
tpolley
kansas city
are those ft lbs? so a 5/16 inch grade 5 bolt should be torqued no more than 19ft lbs and a 1 inch grade 5 would be torqued to 587ft lbs?
dxdexter
Be careful using generalized torque tables. They are based on the use of a nut and bolt connection with full thread contact (I suggest minimum two threads exposed). They would not reflect values where the bolt is threaded into dissimilar materials and varying thread contact areas.
As mentioned above lubrication will have an impact on torque requirements.
Moose-LandTran
