What’s that tick?
J
Jazz1
Thunder Bay On.
Yes. cant seem to upload the video or copy to this site. Maybe later,,,warmed up engine and snapped off 2 exhaust manifold bolts,,plan was replace manifold gaskets as FELPRO for this engine was only $3.00 at RockAuto….life *****
Bert_
NW Iowa
Had an 89 4.3 that had a lifter tick at hot idle. Been that way for over a 100,000 miles. Never did get any worse.
J
Jazz1
Thunder Bay On.
thanks for responses…so I’m going to leave the 2 broken exhaust manifold bolts as I’m considering repainting my 10 year old paint job…the broken bolts had no effect on ticking
GoToGuy_Ron
We used a adjustable nozzle spray bottle with soapy solution to narrow it down. Also sprayed some white krylon paint around just around flanges to get exhaust trail.
wssix99
Chicago, IL
An infrared thermometer will show you a leak real easy.
Are you sure the leak is causing a tick? Could you have air being sucked in causing a "pop" inside the exhaust if you are running a little rich?
J
Jazz1
Thunder Bay On.
I removed front clip to access the 3 broken bolts.
