Don1357
and one that costs 1,000% more? And I mean for the home garage dweller.
You mean the angle die grinders?
If so;
-Heat treat of the bevel gears
-Backlash of bevel gears, aka, better tolerances on the depth of the pinion gear and contact area.
-Better Bearings
-Quality of motor parts, such as vanes, porting, deburring, etc resulting in better power and longer life.
Just to name a few.
I am genuinely not sure what point you're trying to make here?
If you don't think a name-brand die grinder is worth it for you, buy the cheap one and see if it does what you want it to do. If it doesn't, replace it with something better. If it does, great!
Or I could learn from the experience of others by posting on a tool forum.
There are tools where it absolutely makes no sense to buy cheap, like screwdrivers and generic tools shaped like adjustable wrenches, only disappointment comes from those. There are tools where the cheaper alternative works every bit as good as the much more expensive ones, some hammers and my 2" clamps come to mind, I got HF and Pony of the latter, I reach for either when I need to use them). And there are tools that lie in the middle, and how you use them has a huge say in the matter.
The HF air grinders **** IMO, I legit have trouble cutting with them using a 60 gal air compressor at home and I always revert to my electric corded grinder because it is that bad. I am also talking about the very cheap air grinder that's like $10-$15.
Don, what do you have for a compressor? Die grinders, though small, are air hungry units. Even cheap 1/4 - 1/3 hp ones can draw 8-16 CFM at full song. The advertising is all over the map for them, and the number stated on the packaging is always at a duty cycle...usually a 25% or 50%. So a “4CFM” die grinder, in real numbers, is more like 8-16 CFM actual flow rate. For continuous use you are looking at a 230 Volt compressor.
Dropped my hf one and the air fitting snapped off but it was the tool that broke not the fitting so i went and got another one.
Lots of great info guys, I really want to thank everybody for taking their time on educating me.
I have a 60-gallon 13.5CFM@90. Heck 5.5 more CFM @ 90 PSI if I put my portable compressor inline. It doesn't need to be pretty, it just needs to work
For the 13.5 CFM, what would be decent around $50? While we are asking, what's good on a 4 1/2" angle grinder? That I abuse like you have no idea so I would want to get something decent, don't care to even look at the bottom end, but I don't have the air to really run a really powerful one.
I bought a HF to try out after using my buddy’s.
It did the job, but bogged down pretty easily. I used it for a couple of years (I’m a weekend hobbyist, so it doesn’t see daily use)
I upgraded to an Air Cat. Holy moly, talk about a difference. The 6280 is .75 hp. Comfortable to use, lots more power. It doesn’t bog down nearly as much.
