Whats the difference between these triple squares?
airbuff101
Top set is 1/4" dr.
Bottom set is 3drive sizes and include several BIG sizes that I've never seen used on cars. Perhaps trucks/large equipment in Europe.
That VIM series is great, tough stuff and beautifully made. My son has been using the 1/4"dr. short allens and torx sets for a couple/three years day in/day out professionally. Good stuff.
airbuff
Moose-LandTran
The Brink of Insanity (England)
Top set is 1/4" dr.
M14 is used a fair bit, but mostly on VW-Audi cars for suspension, and some headbolts. M16 is used from some VW-Audi brake caliper carrier brackets (Touaregs, Q7s.) and for numerous gearbox fill/drain plugs on certain VW-Audi cars and Porsches. The only use i know of for M18 is large commercial diesel engine headbolts and some VW hub bolts, but you need at least 1/2" for that. (My VW factory tool for the M18 hub bolts is 3/4"-drive.)
2oolhound
BC Canada
The expensive set is made from one piece of steel while the cheap set has the body plus the drive bit inserted into it so it is 2 different pieces.
muskaman67
Top set is 1/4" dr.
airbuff
i checked the vim tools website and it says that the top set is 3/8" drive.
airbuff101
I stand corrected then Muskaman.
The 1/4" sets that I referred are packaged the same way and I assumed they 1/4" in the link.
Good stuff in any size though.
airbuff
