Whats the trick
Craftsman86
Savage MN
I got this beast of a top box, and want to take the drawers out of it to warranty some of the slides. But for the life of me I can not figure out for the life of me how to take these slides out. I am assuming that you drill the rivets, but did not want to drill anything until I was informed.
We are thinking that it is a KR533C
Don't drill the rivets! It may require a special tool but some of these can also use a hacksaw blade to release the catch Most friction slides almost invariably use a spring loaded catch and it can be released either by pulling back a spring (i.e.craftsman, Kennedy), poking a nail or something to depress a catch flat while you pull (Older Craftsman), or slipping a flat object inside to allow the catch to be slid over... (Common on SO.)
Jagmandave
Overland Park, Ks.
On mine the tool used to remove the drawers looks like a feeler blade with a small bend on the end. Bring the drawer all the way out, then push it back in an inch or two, slide the blade in and pull the drawer out - you need one for each side.
C
Craftsman86
Savage MN
Can you post a pic on here of that little gizmo. And now the obvious question where do I get it and how much
spongerich
Monroe, NY
I've had good luck with hacksaw blades for most kinds of slides. Thinner is better. Grinding or beating the set off of the teeth helps too.
gmt830
The Edge of Houston
Look at the drawer side from the inside you will see a small dimple stamped into it. On the outside of the drawer its a bump covered by the slide. At the end edge of the drawer slide you will see a small flat blue strip of spring steel rivited to the guide. The end of that impacts the bump on the drawer and keeps it from pulling out. You need a flat metal shim to slide over the spring steel and allow the the drawer stop or bump to glide past it.
C
Craftsman86
Savage MN
Thanks guys There is something rattling around in the bottom cant wait to see what it is.
Very glad I didn't drill them
