What's this called in English (nails)?
mawrick
Norway
Can anyone tell me what these "nails" on that holds together this wrench would be called in english?:
Also - would it be possible to drill out these and replace them ? (any tips on how ?).
Just thinking of rebuilding an old wrench that have similar nails - but not sure if it's possible?.
thnx
Harrison2
Bay area and UK
Re: What's this called in english (nails)?
german: Nieten
spanish: remaches
russian: заклепки
any other language needed?
puttsy
Iowa, USA
Yes, drilling them out is usually how it's done. Make a mark in the center (usually with a centerpunch), then drill through it. Some people sheer off one side of them though, but that scratches the item your working on. And as others said, rivets.
mawrick
Norway
where would one get new ones, and are they just "hammered" back in ? - any info on that?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
You'll have to get a rivet the same size, then peen the opposite end from the head, over.
Normally the rivets are a hard rivet, and the only true way to peen or roll the other end is with an "orbital riveter". Seeing that the average person doesn't own an orbital riveter, you'll just have to try your luck peening one over. If you don't have the proper shaped punch, what you will need to do is take a flat punch, and start working around the edges rolling the edge over. You'll have to do this all around the rivet quite a few times. The other way, if you have a lathe, and again, it is dependent on the rivet diameter, you would have to dish out the end of the punch, then keep working the punch around the rivet while constantly tapping the punch.
If you ar working in a factory that does assembly work, ask one of your friends if they have a TAUMEL RIVETER. That is the most common brand name for an orbital riveter. It takes a lot to roll over a hard rivet. For one, you will be working with a hardened stainless rivet instead of an aluminum rivet.
Good luck and let us know how you come out. If you get the rivets you need but don't have or can't make a punch, let me know. I've made quite a few thousand over the years.
kbs2244
Peening rivets are what ball peen hammers are made for.
Something of a lost art though.
Everything Kevin said ! Which is why most folks replace rivets with a bolt ad nut. Not as good, but easy to install.
Hey Kevin, how well do these work ?
Obviously, they only work on small rivets. Aluminum for sure, but how about mild steel ?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Actually those do work quite well. They do take a little muscle though, and some coordination to use them if using them on smaller parts. You need a third hand. The women at work complained about them to HS&E to get out of work because they said they were too hard to squeeze. I'd like to have a pair here at home.
Murphy4570
West Deptford NJ
Rivets are a giant PITA. I just spent a day torching and beating out some to replace balljoints on a Dodge Dakota yesterday. Not fun at all.
Best way to install rivets, IMO, is when they are cherry red hot. Heat and beat. Just like how the old ironworkers build skyscrapers in the 1930's or the early iron ships of the 1860's-1910's.
Been there, done that !
The trick use a cold chisel and hammer and shave the river down, sliver by sliver. Once flush, pop it through with a punch.
Oh yeah. wear ear protection ! All that hammering will give you a headache !
