What's up with this hanging ground wire?
bw77
Upstate NY
Visiting in-laws house, I noticed this 10awg wire is attached to a copper pipe that serves
an outside faucet. But the end of the wire is just hanging in the basement.
The copper pipe is properly grounded near the main shutoff valve.
At one time did the wire pass through the hole in the outside wall (now used for fiber cable) and
was attached to the top screw in that device on the siding that looks like something
for a satellite dish? Was it meant to be a ground for the satellite cable?
Wrench97
Southeastern Pa
Those fittings in that block look like what the cable company uses here for multiple hook ups in dwelling.
Unused and no longer needed, Now they all like to run there own ground rod into the ground.
mm08822
You can remove it all if nothing in close proximity needs it. Looks to me like just a partial demo of the cable which isn't uncommon.
dave*99
Coastal NJ
I hope they tie their own ground rod to all others on the property. Otherwise bad things can happen.
