What's your favorite grease?
chris142
apple valley,ca
For cars,trucks etc. I used Valvoline 3% moly for years then one day I found it had turned into liquid in my wheel bearings.
I kinda himm hawed around. Looked at grease specs and settled on Lucas red and tacky. Not that I think it's the absolute best but it's available almost everywhere from Walmart to Napa so getting it isn't a problem.
It does meet some pretty good specs. What do you use?
toyotadriver
I have three grease guns with different greases for different needs. Generally from what I understand (I'm not a grease expert) you do not want to use moly greases in wheel bearings. Moly grease works great in pin type joints like a front loader because it's an extreme pressure grease. Personally, I use Lucas Red and Tacky or Mystik JT6 (most things including my loader joints), Green Grease (for certain small bearings although I think it would also work very well for all wheel bearings), and Super Lube silicone grease for anything that uses plastic bushings.
C
chris142
apple valley,ca
I have heard the moly thing too. But my F250 calls for moly grease in it's repack able wheel bearings.
AldeanFan
Niagara on the Lake
Most grease has been out of stock locally for almost a year.
I like red n tacky but it’s not currently available anywhere I shop.
I have some mystik on the shelf that I’ll use instead.
Any comparable grease is good and any grease is better than a dry bearing.
C
chris142
apple valley,ca
No problem finding greases here in California
nbpt100
Massachusetts
PB Blaster has a Lucas Red and Tacky alternative. At the big Orange box store.
like2wheel
On an as needed basis
I heard the the problem is with the company that manufacturers the tubes that the oil companies need to package the grease.
Not sure if it's true, but that would explain why the problem is widespread across so many brands.
nbpt100
Massachusetts
So does this only effect grease tubes to go into grease guns? Not other styles of packaging like canisters.
C
chris142
apple valley,ca
I have seen that at advanced auto. But there are no specs to be found any where on the www
nbpt100
Massachusetts
It is a NLGI Grade 2. Do you need to know more? I am not an expert on grease. If I wanted to learn more I would 1st go to BiTOG.com
C
chris142
apple valley,ca
I'm a member there. I would like to know the 4 ball wear test and timkin load rating... Nobody knows.
Firebrick43
West central Indiana
NLGI grade 2 just denotes how thick it is, similar to oil weights. Has nothing to do with its performance.
nbpt100
Massachusetts
ok, I see. Most specs I have seen just indicate a NLGI grade and sometimes maybe a base material like lithium...... or contains moly.
Well since no one else is gonna say it,
I'll see myself out! Hahaha
No need to leave. We need some comic relief. Kind of a dry topic that needs some lube. pun intended.
CraigStu
Blacksburg, Va
I have been using red synthetic grease usually Mobil1. I like synthetic because I don't think it can hurt anything like a petroleum grease can weaken plastic. I also notice it turns black in use, so I keep pumping in red until the stuff oozing out is also red. I 'think' that means I have gotten rid of at least most of the old stuff.
coldh2o
Ontario, Canada
Red n Tacky is available on Amazon.
Junkman
Northeastern CT
If you want to grease my palms, I sure hope that you are going to use $100 bills, but beggars can't be choosy, so even dollar bills will work. On my tractor, I use red grease. I have 2 cans of Lubriplate, one is a low-temperature white grease and the other is a high-temperature white grease. I bought them both at a swap meet for $5 a can, but haven't used much of them since I am not exactly sure what the proper application for them is. As a lot of "good deals" at swap meets, you buy because the price is so good, but you really don't have an immediate need for it. The Red grease is a high-temperature multi-purpose grease by Valvoline and was on sale for $2.50 a tube at NAPA.
bwringer
Indianapolis
I use grease the most on motorcycles, so I'd say I go through the most Bel-Rey Waterproof grease:
Lucas Red-n-Tacky is another great choice for this sort of stuff, and is what's in my grease gun on the rare occasion I encounter a grease zerk. I've stuck with these two over the years for things like suspension bearings, steering stem bearings, and suchlike. That way, if it's red, I know I can use the Red-n-Tacky, if it's blue-green, I'll use the Bel-Ray. (And if it's something else, I make sure I wash out all the old stuff.)
In my trailer wheel bearings, I use Lucas X-Tra heavy duty green grease; it's supposed to be a little better for high-speed applications, I think.
In truth, there's likely little difference in actual use; it's far more important to use grease, any grease, where it's needed than fussing over which exact grease is optimal.
Also, Lucas is a semi-local company and buying Lucas grease helps support our local football stadium... they're very high-quality products and easy to find around here.
Mfaz28
Lithium grease should not be underestimated, but as previously stated. It’s not for every application. Moly, PTFE All have uses.
Mytoolsupply
Central Ohio
I've been a big fan of the Premalube by certified labs lately. I personally think it blows the Red N Tacky out of the water and I noticed my overall grease consumption went down after I started using it. Only down side is you have to buy it by the box which I think is 48 tubes but typically a box will get me through a whole year
marinusdees
Edgewood, Washington
KY Jelly
