Whats your favorite 'unique' tool?
WWheeler
Middleofnowhere USA
Menda Wire Threader.
I believe it's a tool developed for aircraft techs, but it's a cheap but indispensable tool for anyone who ever needed to open up a wire harness (slip this under the tape and cut against the 'V' in this tool to eliminate the threat of cutting any wires) or squeeze a wire though an existing wire loom clip or zip tie, etc.
Iridium rand
Surprisingly no matter how hard it seems to avoid I’ve never actually cut a wire doing this thousands of times, but this would definitely be mentally helpful and probably moreso in certain areas with tightly packed wires and not a lot of room or visibility for the cutters
N
noid
This thing has been awesome for desolder older boards. No more messing around with a manual sucker.
I find it best to apply a bit of flux on old solder joints, then flow in a small amount of 63/37 and then **** it up with this thing.
Bulldog13
Cape Coral ,FL
O2 sensor wrench….split ring pliers….makes a crappy job so easy
gilbo
Neat tool! I just found this Japanese YouTube video demonstrating the tool. You should make on in English.
As others have previously stated, one of my favorite unique tool that I’ve now had for a few years is the Merry HS175C disconnect/connect plier tool.
Back then at the time I first came across them I was kinda skeptical about them but once I actually started to use them, that was it. I was hooked!
Glad I got them. You may not use them all the time but they sure do come in handy when called for and makes life a little bit easier IMHO.
I ordered it because of your thread and it's really useful. Thank you!
GREAT call on the pliers, It will come in handy.
ecotec
A couple of people have suggested split ring pliers.
I use this style pliers for split rings.
