Wheel alignment plate
fourjeepin
Atlanta, GA
Have any of you used these and have an opinion on them? This will be for my ‘79 CJ7. I drive it on the street but very low miles per year. Current alignment was done 4+ years ago and was eyeballed.
Random pic from Amazon; I haven’t purchased anything yet as I am still on the fence if this is a good idea or not. But I am leaning towards it due to the low miles and generally low speeds my Jeep sees. Not to mention the complete lack of original parts plus I would be shocked if the frame was straight due to rollovers and frame breaks
Steve W.
Southwest oHIo
For the apparent low-demand usage, I would suggest splurging on a professional job, then it’s good for at least a decade or so.
Fedwrench
Valley of the sun
I haven't used the plate but, my main concern would be you're using a bracket instead of the suspension being at ride height and at rest. How many angles are you measuring with the bracket? just Toe? what about camber, caster sweep, etc. A real alignment might reveal that you have frame issues but, at least then you would know. How much is the bracket compared to an actual wheel alignment?
WildBill
PNW
I use this app and phone holding jig setup, works great for doing home alignments. Came up with almost the exact numbers as Les Schwab did. Also lets you check things like body vs axle angles. https://gyraline.com
DAWrench
Central AR
If you are just setting toe in I would just scribe a line by spinning tire and use a tape measure. That how I do my Jeep and it has always worked for me.
ATC
VA
Just use a piece of angle I assume you have or can find for free...it works very well for a seldom driven vehicle
Milton Shaw
Ride height is what changes the alignment in the first place. Get the car/truck back to the right height an caster/camber will normally be a lot closer to what it should be. Doing an alignment on jacks has no chance of being accurate. You might as well just chalk the tires and drive it down the road and look for the pattern that were worn off. Outside wear toe in, inside wear toe out. If there is feathering on the tire then toe in is probably the problem. 1/8 inch wrong drags a tire 30 feet every mile you drive. Get it done right and everything broken fixed or welded if broken. Your life is worth fixing it right is the only way to think of car repair.
F
fourjeepin
Atlanta, GA
That looks spectacularly flimsy.
Agreed; it was a bad example to show. This is more like what I am thinking 1759352052641.png
I am only planning to use this for checking toe. My caster is fine. Camber needs to be checked as it could also be causing the tire wear I am experiencing. I bought a good digital angle finder recently for this.
Will checking this will on stands make a difference? Ride height def changes with a more advanced suspension, which a Jeep CJ is NOT. Mine has leaf springs front and rear and it doesn't even have sway bars.
I considered this as I like to build stuff, but for the price these go for and my limited time for fabrication, I decided to buy vs. build.
