I have another thread about using my wheel balancer yesterday. But I was wondering about how it calculates the amount of weight needed depending on the location. I have one of the generic import electronic balancers. You input the data it asks for and it initially spins up and gives you the weight needed. If its a wheel (steel) that you can hammer on weights to the inside and outside lips than thats all you need to do. If its an aluminum wheel that you need to use stick on weights in different locations or a combination of hammer on and stick on weights there is a button you press that moves it thru a display showing 4 different scenarios. As I was moving thru the different scenarios I notice a decent amount of difference between the amount of weight it was calling for. Its seems like on the initial spin where the weights would be attached to the farthest from center point, the weight was much less. As the weight moved closer to the center and closer to the face of the wheel it took much more. I am guessing because the mass of the wheel is the face and it would take more to make a change happen? Any other insight? Just trying to learn something.
