when can I epoxy my garage floor?
icefisherman
mn
I am going to acid etch my floor, after i do my final rinse how long do i have to let the floor dry out bfore i can epoxy my floor? I will be using sherwin williams macropoxy 646 which is a two part solvent based epoxy. Its been in the 60s and 70s lately if that helps. Concrete is 7 yrs old.
sicklyscott
I read something here about duct taping a peice of plastic to the floor overnight to see if any condesation showed up. If it did, you need to wait longer. If it was dry you were good to go.
Of course I've never done epoxy before...
rugerlady
Depending on humidity, the day after you etch it should be dry enough to apply the epoxy. Always double check with the manufacturer of the product your using and see if they have any guidelines for their specific product. Hope this helps.
AlphaGarage
Every Garage, AnyTown, USA
The "tape down plastic test" is to see if your floor has hydrostatic pressure; that is moisture being wicked or forced up from the ground underneath the slab. Excessive hydrostatic pressure can cause coating to separate from the concrete - not a good thing.
Different coatings have more or less tolerance for that moisture, so if you do run the plastic test (use a 3' b 3' piece of plastic) you'll want to check with your supplier about what to do.
If it's a lot of pressure there are solutions, some very good ones, but they can be pricey.
As far as the original question of when you can coat after rinsing a floor - again, depends of the coating (seeing a pattern here?). For example, many epoxies require a bone dry surface, whereas our Bondtite 1101 can be applied while the floor is still damp, that doesn't mean "moist," and there can't be any standing water, but if yo see areas where the concrete has become light, you're probably good to coat.
