When do you oil your air tools
KMinAF
Fairview Utah
Every day I pull the trigger, load it with a full squirt of ATF from the oil can then run it over the trash can for a couple of seconds. Wipe off the excess and I am good to go for the day.
Jeff Ivers
Oklahoma
Whats your preference on when to oil your air tool, before use or at the end of the day for the next day?
Niether. I oil continuously with an automatic oiler. It was inexpensive and I set it up with male and female quick connects so that I can snap it on the airline just ahead of the tool I am using or remove it if airing tires, using blow gun, etc. It is way too easy to run a tool too long for the drop or two of oil put in the previous day or just before you started. I like my tools to last!
Shipfittin
Portsmouth, VA
I always oil my air tools before I use them. Sometimes they even get a little more oil later in the day, depends on how much grinding I am doing.
AdamH
Scituate, RI
Oh man, I didn't realize that you were supposed to oil air tools that often. Granted I'm only a weekend warrior I think I've only oiled my impact like 3 or four times and I've had it for at least as many years. One time it even stopped spinning until I added a couple drops of oil. This was with a cheap set of Norther Tools air tools too.
Guess I better get on the ball with this then.
Techniker
I'm a bit obsessive compulsive so I actually oil them every time I have to reconnect my air tool. Air tool oil is supplied by the shop, so I don't mind. If you saw the air lines here, you wouldn't blame me either- you can use them as water guns...
Techniker
Oh and speaking of which, there is something for this in a recent post I made on the Hot Deal Index:
http://www.garagejournal.com/forum/showpost.php?p=1389203&postcount=4084
From Amazon, Ingersoll-Rand Filter-Regulator-Lubricator - Piggyback Style on sale at $46.99, regular $219.00. The next closest price I can find is $134.99, so it seems like a good deal.
<a href="http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2FIngersoll-Rand-IRTC38221610-Filter-Regulator-Lubricator-Piggyback-Style%2Fdp%2FB0040Y50DY%3Fs%3Dautomotive%26ie%3DUTF8%26qid%3D1299453425%26sr%3D1-231&tag=thesciesnote-20&linkCode=ur2&camp=1789&creative=9325">Ingersoll-Rand (IRTC38221610) Filter-Regulator-Lubricator - Piggyback Style</a><img src="http://www.assoc-amazon.com/e/ir?t=thesciesnote-20&l=ur2&o=1" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
johnsdeere850j
Oklahoma
Does it being 1/4 inputs bind up the flow too much? It says its rated for 58 scfm which is a itty bitty bit higher than cfm...for example, air compressor has 1/2" outlet and you neck it down to the 1/4 for this thing, then on the other side you go back up to 1/2 for 1/2" hose, is that going to really restrict flow?
Techniker
You know, I hadn't really thought about that and I really don't know- the way you put it makes that certainly sound so, but I suppose it depends on the application. Since I am just mounting it to the side of my service cart to power one tool at a time, I think I may be okay. Does anyone here know for sure? :dunno:
Thanks in advance,
Techniker
