hondacivic247
- Joined
- Sep 15, 2014
- Messages
- 538
So I currently have a older 1988 Rolair k25 pump with a 60 gallon vertical tank that has a century 5hp 3450rpm motor driving it. This compressor doesn't use a magnetic starter box I has a 30/50 amp plug that plugs into the receptacle. Anyways over the coming NY winter I want to build a bigger and badder air compressor that makes between 20-30cfm as my k-25 pump is making around 16cfm at 130psi.
So here's my question If I pick up a older quincy, t30, champion, Kellogg pump or one of the older pumps and hook up a 184 frame 5hp Baldor single phase motor, will I need a magnetic starter box. I don't want to get in over my head with wiring as I know the basic's I just wired up 10g 10-2romex from my panel with a double 30amp breaker to a 30/50amp receptacle for the Rolair 60 gallon I got right now. I don't have a disconnect box or anything installed as I'm only 10ft from the panel in my home garage.
I'm wondering how hard it will be to wire in this magnetic starter to the pressure switch and if it needed.
