When just one isn't enough
Bert_
NW Iowa
I'm not much for multiple of the same tool but sometimes you just need it!
And yes, it's twice as fast.
LXCam
Even the largest shrink tubing doesn't take that much effort. Sooo just how many windows do you have to scrape the finish off of?
Bert_
NW Iowa
Windows are done except for four upstairs that need new sashes. That's another job. Stripping sashes with one gun actually wasn't bad.
The current project is the front porch. At some point it had been closed in with some aluminum storm windows. It's going back to an open porch.
The exterior had been sided over with vinyl but that will not be going back on. Had to replace a little wood here and there, most of the damage was caused by the vinyl overtop. And of course everything has many layers of paint. So in the interest of making it last and look decent it's getting stripped.
From this.
To this.
I kind of want to try three heat guns.
Bert_
NW Iowa
Hey if it works, it works. I laughed when I seen the picture of them duck taped together.
:thumbup:
I made the thread as a little bit of a joke. The heat gun is for real, I've been using it. Gotta be able to hold it with one hand. Sure beats dry scrapping!
But it's kind of the polar opposite of what most post about here. Lots of people with a bunch repeat tools. Usually pretty well polished. Nothing against that, I'm just more about getting the job done effectively.
captain14
I like it. I used a heat gun and scrapper last fall on my 80 year old garage door. Lots of work involved.
Two photos of the work in progress, one patch installed and the finished door about 26-27 work hours later.
BlakeTheCarGuy
Roanoke Virginia
:thumbup:
Definitely beats scraping for sure. Yeah I don’t polish my tools either that’s weird in my opinion.
Fialaja
I have multiples of most tools because:
1-if I lose 1 I can keep working and find it when the job is finished.
2- If 1 breaks, I have a back up
3- I found the tool on clearance at a store for a great price and bought the lot
4-said tool is of a vintage that tools were well made and these tools are getting harder to find
5- e- bay
6- I am a tool addict
7- I may be. Hoarder
Fialaja
Reason 8- I am working with somebody else and don’t want to fight over tools or wait till they are done with it for my turn.
matt_i
I've worked with my Dad before sweating some 1-1/2" copper pipe where the little bottle propane torches we had at the time were not going to cut it, using only one. So we both lit one and brought the temp up enough to flow the solder.
It worked just great like I am sure your tools did! :thumbup:
Formula
That’s cool. It reminded me of the movie Aliens. For those of you that saw it, you’ll know what I’m taking about.
Bert_
NW Iowa
I've never seen the movie. The picture is 2-3 guns of some sort stuck together?
toolchaser
Greenville, GA
She straps a flame thrower to a projectile firing gun to go after the creature. Not a huge Sci-fi guy myself, but the original is a classic. I used 2 heat guns simultaneously to heat an engine block for painting, but on seperate stands, not ganged together
Dave455
Sussex, England
It’s an M1A1 .45 with parts of a Franchi Spas 12 stuck on!
Not a huge Sci Fi guy myself either, but the original film was definitely something of a classic!
CoogarXR
Reminds me of over the winter, I zip-tied my heat gun to an 8ft 2x2 and held it up to my motion light that had frozen up. I was too lazy to get the ladder, plus the ground was icy, lol. Sometimes you gotta do what you gotta do.
bonneyman
Desert SW
One of the few sequels that can be seen first and doesn't really lose anything. Also the sequel is equal to - I'd say better in some respects - to the original. Worth a Saturday night when the kiddies won't be watching.
The prop guys took a Thompson submachine gun and attached a modified Remington 870 pump action shot gun underneath the barrel. Then Ripley took a liquid fueled flame thrower and nylon strapped and duct taped the two together.
The Marines - when it absolutely, positively has to be destroyed overnight!
https://avp.fandom.com/wiki/M41A_Pulse_Rifle
DHCrocks
Hawaii
Did you run that off a single circuit or did you have to use two different ones? Just curious cause I know those guys draw a lot of amps and was thinking that it would trip a single breaker running two for extended periods.
Bert_
NW Iowa
Hmmmmm, this isn't what came to mind when I read the title.
Hey I figured a good title might make up for the tool. :dunno:
I was figuring two at first but they're 1200w guns. Together they're right at 20A and it hasn't tripped yet, even with some lights on the same circuit.
charbar
Midwest
:thumbup:
Amen. Pretty sure a lot of guys here would spend 10 hours on a lathe making some bracket to hold them together and then have a 4 page long thread about how to wire the two to one plug.
:lol_hitti
