When to install epoxy floor
Airborne Ed
Bucks County ,pa.
New guy here--I have a new garage going up now .How long do you wait for the concrete floor to cure before you put down the epoxy ?
Has anyone mixed sand in with it ? I am concerened with out that if the floor gets wet it may be slippery as hell . Any info is much appreaciated .
Thanks,
mothgrey
I was told 45 days. I'm waiting also. I think there is an aggregate you can add for traction and non slip. Others with more experience will answer that.
LegacyIndustrial
deerfield, IL
100 percent solids epoxy is too thick to broadcast a nonskid into, it will sink in. You want to add a thin topcoat of urethane, either mix in an additive like sharks grip or our Soft Skid, or broadcast in a fine sand and backroll.
I am assuming you are using a quality solids epoxy as a base for the urethane.
