When to use 1/4" vs. 3/8" vs. 1/2" drives
ajchien
Los Angeles, stuck on the 60 freeway.
I'll use the smallest drive that will take the least amount of effort.
I personally find shorter handles more efficient as it takes less motion to spin off a bolt. Yet, longer handles give the torque leverage needed to break it loose.
So quite often, I break a bolt loose with a 1/2" breaker, and proceed to spin it off with 1/4". It's just faster for me personally.
Assembling depends on how much torque I want to apply. If I'm not using a torque wrench, my right arm is pretty well calibrated for roughly 4ft-lbs per inch of ratchet for a "snug" feel. So if I want to get to 30ft-lbs, I choose a 7-8" long handled ratchet.
sk farmer
nd
Guess you're jealous that at least 1 manufacturer makes a product that matches a standard torque chart very well. I pretty much agree with 1/4 drive up to 14 or 15mm sockets, 3/8 up to 20mm and 1/2 for anything else.
jealous? of what? i own a dual 80 along with about 20 other brands. i also own several other snap-on products so i am not sure what i would be jealous of.
the world got along just fine before the dual 80 and now everyone thinks they have to base everything on one. almost as if unless you don't have one you are an unqualified hack.
the op asks a question about the relationship between socket size and drive size. no mention at all if any brand and the dual 80 fans have to chime in about how awesome it is and how socket sizes should be chosen on it's capabilities. heaven forbid the guy doesn't have one. what on earth would he do?
like i have said before, i have a dual 80. a fine ratchet but not good enough that i feel the need to replace all of my other ratchets or expand my socket size range because of it's torque specs.:p
Adam.C
For what it's worth, my guess is that the limiting factor in most modern ratchets is no longer the ratchet mechanism but the square drive. Therefore, the analysis I have offered probably applies to every high quality ratchet handle. Brand mention is just for those who wish to double check my numbers.
Adam.C
I've been thinking about the responses here and doing some more math.
Pretty clearly, manufacturers limit the largest socket sizes offered for a given drive as torque requirements for larger fasteners could potentially exceed the capabilities of the drive. But, according to my math, the load that needs to be applied to the handle to break it is beyond practical. This is due to the limited length of the ratchet handles (which is what I was suggesting in my last post). Here are some numbers:
A T72 ratchet handle requires a 270lb load, applied to it's end, before it will break. Apply the load an inch in from the end and the required load goes up nearly 100lbs (360). Most of us could stand or jump on one of these ratchets and couldn't break it. This leads me to believe that 1/4" drive is more than strong enough to handle any socket made for it. But I shouldn’t stray too far from my caution about long handles. A 9” TLL72 needs only a 120 lb force to break.
What I missed in my earlier comments was the load required to produce a given torque. This may explain why so many respondents either didn’t favor ¼” drive or chose the cut-off socket size well below the largest size offered for that drive.
For example: A 3/8” bolt requires a 9/16” socket, which Snap On supplies in ¼” drive. While the torque required for this socket is indeed roughly half the capability of the ratchet (30-50ftlbs vs 90ftlbs of ratchet capability), the handle load required to achieve this torque is excessive. A high grade 3/8” bolt may require a 150lb load to be applied to the T72 handle. That’s likely double what any of us would be comfortable with.
The obvious solution is to provide longer ratchet handles with more comfortable grips to reduce user fatigue. But, as I pointed out earlier, there are limits to the safe length of a ratchet. A TLL72 would require roughly half that much force (75lbs) to break free the same 3/8" bolt.
The other part of this that I missed is the smallest socket for a given drive. While the load required would be high, it is conceivable that a long 1/2” breaker, or even my much appreciated SHLF80A ratchet, could shear the head off a 5/16” bolt (using the available 1/2” socket). The torque rating for this drive exceeds the shear strength of many fasteners at the low end of the available socket sizes. This was my caution about long handles.
In conclusion, though I haven’t 100% given up on the idea that there can be a right or wrong answer to the question; "which drive size is appropriate?" you all have convinced me that this is far more complicated a question than I initially thought.
Having given the subject more thought, here is what I can conclude:
1) Mechanics likely have normal range of handle loads they are comfortable applying. My guess is that number varies from 20-100lbs. This may explain the responses here and why some folks' ½” and 9/16” ¼” drive sockets see very little use. Those fasteners need more than 100lbs of handle force for most small ratchets.
2) Tool manufacturers limit socket sizes available. It appears they have a 2 : 1 margin of recommended fastener torque to drive capability.
3) Tool manufacturers offer a range of different handle lengths and grip styles to allow mechanics to loosen and tighten things without having to apply excessive hand force. But there are clearly upper limits to handle lengths, likely based on the capabilities of the drive. We all know what increasing a ratchet handle's length with a section of pipe can do.
4) The capabilities of the drives exceeds the force we are generally willing to apply. This means many of us might be more satisfied with 1/4” drive if we had longer and more comfortable ratchet handles. Those of you who don’t prefer 1/4" drive may find a new longer more comfortable ratchet provides a great deal of added utility. But the wide range of sizes available in 1/4” drive means we need to be careful when using long handles on small sockets. This is generally true for every drive size.
For the OP, my sense is that the limits for a given drive are defined by the range of sockets offered, not the strength of the drive itself. 1/4” drive is fully capable of handling every normal fastener that a 1/4" drive socket will fit on. No rule of thumb is necessary.
But, respondents offering rules of thumb here raise good points. Practical limitations on drive size (for a given socket) are probably based on comfortable hand pressure required to actually use the tool to loosen properly torqued fasteners, and reinstall them to the recommended torque. People who prefer the smaller drives may be the people with the longer ratchet handles or those with premium grips.
For me, my take away is that I will probably buy a THLF72. I now have more confidence in the strength of 1/4" drive.
I hope this wasn't a waste of anyone's time.
48fordnut
mid ga
New to the journal here, but a long time lurker. I have been in aviation most of my life. When I bought my first tool box, craftsman, in 1955 it only had 1/4 drive and 1/2 drive ratchets. I like 1/4 for most any thing, because you have to get your hands into small places.
tibwd
IMHO, 3/8 inch is the "centerfielder" of the 3 sizes mentioned. Go down to smaller sizes easily, clearance permitting, just as easily go to larger sizes, torque requirements permitting. As previous posters noted, let common sense and experience be your guide. One bogey in loosening fasteners is RUST...oftentimes changes the demand for removing fasteners. A full compliment of 3/8 ratchets (stubby-long handle), and a full set of 3/8 sockets, can satisfy a lot of your ratcheting needs in the auto/pickup/home environment. Ken W. rule of thumb was spot on= inside car 1/4 ", under hood, 3/8", and under car 1/2 ".
Wakefield
Arlington VA (but would like to get out to country
For example: A 3/8” bolt requires a 9/16” socket, which Snap On supplies in ¼” drive. 1/4” drive is fully capable of handling every normal fastener that a 1/4" drive socket will fit on. No rule of thumb is necessary.
I would be very surprised if my TM10G (Barbie's breaker bar in 1/4" drive) or my SK 40971 ratchet could take off the blade bolts of my B&S engined mowers without breaking (have 9/16" wrench size SAE fine thread 3/8" shank bolts) put on at about 45 ft. lb. even though my gloved hand could probably generate enough pull with the handle lengths that tiny "breaker bar" does work well for tiny things
rusjack
Ontario, Canada
I use a snap on t72 for 99% of my work. 1/4 drive, rated for up to 90 ft/lbs of torque. That'd be 1080 in/lbs. Pretty much the only reason I ever switch to a 3/8" drive is when I'm hurting my hands with the 1/4.
I'm also working in Aviation, so I don't deal with rusted out bolts very often, just high torques on clean things.
Scotty_B
I know this is a somewhat older thread, but I found it fascinating – both the scientific/technical explanations and learning how different people like to work.
I work mostly on a Subaru and a Honda. That means lots of aluminum and very tight spots, especially under the Honda's hood. That's led to learning to work with 1/4" ratchets most often under the hood – even up to 14mm fasteners (in most but not all cases). You appreciate the lightness when performing long tedious jobs and not having to unnecessarily break out the torque wrenches, which slows you down. Working on largely aluminum engines usually means tightening to "snug," and a 1/4" ratchet is usually just right for that.
Now brakes and suspension? That's a different story!
Dirty Diesels
Nottingham, Nottinghamshire in the East Midlands o
But nobody mentioned the 3/8" drive in a 1/4 body or the 1/2" drive in a 3/8 body, they all have their uses!
turnthewrench 2.0
FL
Guess this is a stupid question, maybe not. Been thinking about this for a spell, well, many, many years actually, but here it goes.
Are there any rules defining when one switches from a 1/4" drive to a 3/8" drive to a 1/2" drive?
Lets say I need to remove a 1/2" bolt from a hoo-ya.
I have a 1/2" socket (Craftsman of course {grunt}{grunt}{grunt}) in my 1/4" drive set, and in my 3/8" drive set, and in my 1/2" drive set. Can use either one of them.
Now, I'll usually grab the 3/8", but, what exactly is the cutoff for 1/4" and when is it overkill to use a 1/2"?
Comfort and torque required are my rules - Usually, comfort makes the day for me.
All depends on how much torque you are going to apply to the bolt or nut. 1/2" drive ratchet and sockets are both designed to take more torque. I have broken 1/4" drive ratchets and sockets by hand with no cheater bar on a 5/16" headed bolt. Clearly needed a 3/8" drive.
How about look at 1/4", 3/8" and 1/2" torque wrenches. The upper and lower setting on the torque wrench is the range for each size?
Best answer yet! I like it!
anndel
Hawaii, USA
Most times it's 3/8" drive first then scale up or down. For lighter torque ~15 ft-lbs, I use a 1/4" since I'm a gorilla and tend to overtorque things.
Snaparxon
Eastor
I think the size of the gear and pawl plus the tooth count factor in. Older Mac ratchets had a thinner gear compared to a Snap on of the same vintage. A Matco CR15 round head has a thinner pawl than the CR15DP round head. I use a Snap on long 1/4" flex with a 3/8 drive kit in it and have yet to have it rebuilt.
Finky198
North East
1/4" Dual80s can easily withstand 90 ft.lbs of torque, wouldn't even think twice about busting it out for motor mounts (most are 50-60ft.lbs tops) and I do it with my TLL72 all the time. I've pretty much retired my 1/2" breaker bar with my FLL80.
I wouldn't trust any of my GearWrench, Matco and Stanley ratchets to stand up to the same kind of abuse I put on my Dual80s.
This. ^^^ Snap on a dual 80s have legitimately changed the way I work.
With the roll out of extra long ratchets like the TLLF72 and FLLF80
I’m using the smallest dive size I can for the given application.
At this point I really only use my 1/2” stuff on suspension work or large fasteners. And Even that has dwindled due to the ease of use and availability of impacts.
Professional Tool User
BC
To me it would depend on the application. 1/4 would be for small stuff like a bolt that secures a relay. 3/8 would before most things automotive. 1/2 will be needed for larger bolt and nut sizes.
Negen
Seatltle WA
Anything below 10mm I tend to use 1/4 anything above that I use 3/8 currently I own only 3/8 cannot buy any more tools until next year. I have 1/2 beaker bars and Wrench's for bigger smaller things at the moment but most my work only requires 3/8. But 7/16 and 1" can be tough to remove with 3/8 but been getting quite a work out.
Sent from my G8141 using The Garage Journal mobile app
Mr Ratchet
An old thread but, good one. Torque and space constraints are the primary aspects that dictates the drive size I choose. There is not size cutoff for me otherwise. A little common sense goes a long way as ken w. pointed out. Maybe more true today as drive tool handle lengths continue to grow longer.
I often use my 1/4" drive 5/8" sockets with my 9" breaker bar and 8" ratchet. I'm not using them to break rusty fasteners loose though.
My SO ratchets don"t take any more torque than my Armstrong or Gearwrench ratchets.
CGarage
United States/Switzerland
My rule of thumb is 1/4" drive for most interior work other than seat belts and seats. 3/8" drive for most under hood york and 1/2" for under car work. There are exceptions but you have to use common sense. You wouldn't use your 1/2" drive to unbolt a valve cover and you wouldn't use your 1/4" drive to take apart your 3/4 ton axle nuts. However I've seen people do this.
Best post here. I do this as well. Though I never thought of it this way as it came as common sense based upon space constraints.
Empty Pockets
Rural New York
Probably the best advise i have heard in some tie. Generally speaking, my "go to" socket set is my 3/8" set, Larger or smaller as the situation requires
giants
California
Thanks!
Your comment gave me a possible solution to accessing water pump bolts on my Toyota!
