When you don't have a work bench....
Alchymist
Central PA
... and you need a vise. Bought this little York vise some time ago, but no place to mount it. Do mostly wood working, so table saw serves as the work bench. Anyway, needed a vise for light duty. (which the York is) and a way to use it. Dug out an old piece of cast iron 10" square by 1" thick, and bolted the vise down. Works a charm for light work. Shown holding a bracked ready for mutilation via cutoff disk.
Larryjones
WV
Have you thought of bolting a pipe flange on the underside, adding a lenght of pipe and filling the bucket with concrete with a socket for the pipe? would be a little sturdier and still removable.
A
Alchymist
Central PA
Mutilated and welded that bracket quite well using the vise as shown. While a bucket & pipe would work, this is real handy... carry it anywhere and when you set it down it stays put for all the light work I expect to put it to.
2oolhound
BC Canada
I see that's a New York vise.
I have an old york vise ;)
You can always clamp the base down on the table saw deck if you needed more sticktion.
Necessity is the mother of invention.
MushCreek
Upstate South Carolina
When I started building my barn out in the boonies, there was NOTHING to use for a work space! Have you ever tried to clamp something in the woods? I made a bracket for my 2" square receiver hitch on the van, and bolted a vise to it. I also built a picnic table so I'd have a place to sit, and a workbench of sorts. I kept the vise on the hitch adapter, though, as I could just pull the pin and throw the whole thing in the van, rather than out in the weather. It always makes me grit my teeth when I see a valuable Wilton vise bolted (or welded!) to the rear bumper of a state or county truck.
A
Alchymist
Central PA
I'm curious as to what precision machine was dismembered to get the cast plate with a Bausch and Lomb label on it?
Scrap microscope base.
Came in handy today needed a way to steady an angle iron frame to slice and dice:
brooksdr
Build a work bench! lol I realize that you might not have room. Good improvising!
