When you need a swivel-jaw vise...
Beerhippie
Far NE Oregon
nothing else will do! Fixing a Kitchen Aid mixer for one of our pub employees (it was her grandmother's). That hole had wallowed out, allowing the head unit to shake up and down. I'm building up a pad of Permatex Cold Weld one thin layer at a time. Once it sets fully (tomorrow), I'll file it down and she'll be good for another few decades!
I gotta admit, my 1911 Reed 404 1/2 spends most of its time just sitting on the end of my bench (I reckon it's earned it) looking tough, scarred and rugged, but when I need it, I need it.
crguy
SW Washington
What is with the bolt in the pin hole?
Beerhippie
Far NE Oregon
It was that way when I found it. It works and looks about as old as the vise, so I left it. The bolt has been tapered to provide a reasonably tight fit.
Besides, finding parts for pre-patent Reeds isn't easy.
Beerhippie
Far NE Oregon
Using a chopped off custom tapered square headed bolt is not a bad way to go. If and when it gets stuck, a bit of a twist with a wrench will free it up quickly.
When I restored this old vise, it required a week or so of penetrating oil, heat, hammers and finally an impact gun to break that bolt loose.
The swivel jaw was even harder:
Here's some of the rust that was packed under the swivel jaw:
Beerhippie
Far NE Oregon
The BFH is a 4 lb, solid tin (probably an alloy, actually) hammer for making fine adjustments on a centrifuge. It's great when You need to whale on something without marring it.
