nicke
Where is the check value on my old Kellogg compressor!?
I noticed the other day that my compressor sounded like it was leaking through the pressure switch, but only when the motor wasn't running. I thought it was my pressure switch finally going bad, so I bought a new one, and threw it on there.
Same issue! Everything seems perfect as the tank is getting up to pressure with the motor running, but sure enough, as it reaches pressure and the motor cuts off, air starts rushing out through the unloader valve on the new (and Old) pressure switch.
So, after a bit of research, I sounds like I might have a faulty check value
For the life of me, I can't figure out where that is. Please help!
Pics of my setup are below:
Thanks
Nick
Thanks
Nick
