where to buy extra long flare nut wrenches?
tommydog35
Is there anyone who makes extra long metric flare nut wrenches. I am looking for something 12 inches or longer.
B_Bimmer
Eastern Iowa
Curious what for? Usually I find I need to take it easy even on regular length wrenches or they'll round off. I haven't ever seen long ones so can't actually be useful in answering your question, but am curious what you're looking into them for. Access, reducing fatigue...
T
tommydog35
I want them mainly to make access easier when removing injector fuel lines from a pump. I have not had much luck with crows foot, as the ones I have tried are a little too wide, as they foul on the other injector bolts. The only thing I have got to work is a standard flare nut wrench, but it cold do with being a bit longer. On the subject of crows foot, can you get slim profile ones with a flare nut head? I know I could take a grinder to my existing crows foot ones, but I am reluctant to do that.
DBendr
One each Not for the faint of wallet :thumbup:
Hiball
Missery
Extra Length + Open end = Not good
I'm not sure what type of injection pump your working on, but I know there is a special socket adapter for older Navistar pumps. It makes things go so much quicker as you can work straight on, versus side to side.
AndrewDouglasBird
Vancouver, WA
You could always get a long handle box end and cut a notch out of it. I've done this to make an O2 sensor wrench before. Cut the notch with an abrasive cut-off wheel as most saw blades won't touch the hardened steel.
