Re: Were to find new air compressor plumbing
That fitting was put on and then the copper tube was flared. I understand you want it to look newer, but you'll probably end up buying new copper tube and use a flaring tool if you go this route. Or paying someone to do it. Another alternative is to replace the copper line and the compression fittings with a hi-temp stainless steel braided line. For individual fittings, your local plumbing supply house will have them. Another option is to take your old parts and go to your local air compressor dealer. They should be able to make exactly what you need on the spot, including bending new tube. But they may look at you funny and question why you want to do in the first place. Or look up the parts manual for your compressor and buy the assembled part online.
