Where to find this toolbox part...
nickaudette
Virginia
Anyone know where I can find this? I searched with "j bolt" but didn't have much luck since it's almost more of a U style. It's for an Adrian Steel Aluminum tool box. One is working the other snapped so looking to find a replacement. Anyone know where to find, or what to better call it?
Thank you!
lilredex
Toronto
Did you look at muffler clamps or a portion of it?
A picture would really help with a practical solution.
KnurledNut
n/a
If the manufacturer couldnt provide it, i would probably look for a U-bolt of similar dimensions, and modify as needed.
Like this:
N
nickaudette
Virginia
Yeah, I had a feeling I'd have to get a u bolt and modify it. I guess I'll go that route.
Any input on struts? Need to replace one so I might as well do the pair. The problem is the diamond plate was ripped out on one side where the one strut mounted to so I was going to mount a few inches to the right (closer to the front of the box).
Should I get a little longer struts? Or just get the same ones, they were suspa C16-04445 17" struts rated for 55 LBS each.
https://www.amazon.com/dp/B007MUY728/?tag=atomicindus08-20
If you change the mounting location of the strut, you are changing the amount of work it does, so you may need to change the capacity of the strut. I would just put a plate over the damage.
DFB
Southern VT/Western Mass
whats exactly are the the dimensions
Simple U bolts that look similar to that generally can found in hardware stores but usually only in small dia. sizes
I needed some 1/2" thread ones for my 3 pt rototiller one fatigued and snapped due to some vibration over the years I had a local truck spring shop form up just what I needed while I waited.
