NewShockerGuy
Seems like my maxjax from 2011 has been revised. Because the seal kit that I had sitting around for the one cylinder is clearly different that what I have. I did a little digging and it appears that after 2011 Dannmar revised the cylinder.
So now I have a cylinder that leaks but can't find a rebuild kit for the original build date/serial of mine. The kit that I have everything is too large. I called some local shops and they are wanting around $250 or so to rebuild or figure out what is needed. A new cylinder from maxjax is $400.... so I can't see spending that much when I can just get a new cylinder. However I just need the seals..lol and would have no problem rebuilding it.
Anyone run into this issue? Cause seems super silly to throw this out for $80 worth of seals.
I've attached a couple pictures.
I think the main problem is my green lower seal just gave out. That's fine. But while everything is apart I figured re-do it all
My cylinder has two spots for gaskets/rings, and the things I've finding online the revised it to 3.
I've attached what the revised one looks like:
Thanks,
-Nigel
Thanks,
-Nigel
