BentBierz
Hello,
I have a detached 1500 sq. ft. building that I am converting one side to a wood shop. There is a 100 amp panel coming from the main that is on the opposite side of the building from where I am going to set up the shop. The panel is very lightly loaded and has more than enough space to run my 240V shop equipment that includes:
- Sliding Table Saw (30 amp)
- Band Saw (30 amp)
- Drill Press (15 amp)
- Lathe (20 amp)
- Dust Collector (30 amp)
- Air Compressor (unk...not certain yet what I want/need)
- Misc. other circuits for miter saw, powered hand tools, etc.
* Amps are required circuit breaker sizes, not the typical equipment load.
Unless someone else is working with me in the shop at the same time (very rarely), I will never have more than two pieces of equipment running at a time, one of those being a dust collector.
I have several different options I am considering:
1. Run separate circuits off of existing panel for each piece of equipment.
2. Drop a 100 amp breaker in the existing panel and run to a new 100 amp panel on the wood shop side of the building (approx. 60' of wire run).
Option 1: I guess the primary advantage of this option is that I have the available circuit space, with some to spare, so wouldn't have to buy a new panel or more costly heavy gauge wire but will have to run more smaller gauge wire and conduit.
Option 2: Advantage of this option is theoretically less conduit/wire to run to get to each dedicated circuit.
BTW...I have two steel buildings and will not run Romex in either. It is probably the German overkill in me but I like conduit as it protects the wiring better. We live on acreage out in the country and get the occasional rodent in our buildings that like to chew on things.
I would appreciate thoughts from those that have done this in the past. Thanks.
- Band Saw (30 amp)
- Lathe (20 amp)
