which air compressor
hardbody
I'm in the market for a new air compressor and cant decide which one. An EMAX or an LaPlante. I'm looking for valuable info on them.
Model
Model Number: EP07V080V1
Manufacturer: EMAX
Motor
Running HP: 7.5 HP
Voltage: 208-230 Volt AC
Phase: 1-Phase
Magnetic Starter: Yes
Pump
CFM @ 175 PSI: 26
Max PSI: 175 PSI
Pump Material: Solid Cast Iron
Pump Type: Two-Stage
Continuous-Duty: Yes
Tank
Tank Size: 80 Gallons
Tank Outlet: 3/4 Inch
Tank Orientation: Vertical
Accessories
Auto Drain Valve: Yes
Overview
Certification: UL/CSA/ASME
Dimensions: 33L x 24W x 73H
(83.82 x 60.96 x 185.42 cm)
Product Weight: 908 lbs (411.87 kilograms)
Consumer Warranty: 5 Years
Model
Model Number: V120101-452
Manufacturer: LaPlante
Motor
Running HP: 10 HP
Phase: 1-Phase
Pump
CFM @ 175 PSI: 31
Max PSI: 175 PSI
Oil Sight Glass: Yes
After Cooler: No
Tank
Tank Size: 120 Gallons
Accessories
Auto Drain Valve: No
Air Dryer: No
Air Filter: No
Overview
Certification: ASME/CRN
Dimensions: 25.9L x 41.9W x 72.8H
(65.79 x 106.43 x 184.91 cm)
Product Weight: 980 lbs (444.53 kilograms)
Consumer Warranty: 1 Year
kams1973
Amarillo, TX
The first appears to be a Saylor Beall clone and the second a Kellogg American clone. For that kind of money, a used American made (non-clone) unit can be had for much less.
Helomech74
The EMAX is made by Airbase Industries which are the makers of the Eaton (Polar Air) compressors. You can get the same exact compressor with the Polar Air name on it for much less then the cost of the EMAX and they carry the same exact parts and warranty on them, plus you get your choice of color on the Polar Air one. Just as a note, Air Base Industries (Eaton Compressors) also make a few of the larger Speedway compressors and also the HULK Power compressors, but those don't carry the same warranty even though they use the same parts.
IndyGarage
Indy
What's the usage? If it's for a production garage, don't buy a clone, buy the real thing.
If it's for a home shop - I agree above. I have two industrial strength name brand compressors - one at home and one in my shop, and got both of them used at a much better price than I could buy a clone. They both run like a top and are quiet and powerful.
creativecars
Indiana- where horse and buggies still roam
Not to hijack, but I too am looking at a real compressor, I have one to air up tires. Is this one of the Speedway compressors made by Eaton???http://www.amazon.com/gp/cart/view.html/ref=gno_cart
If so I may jump on it. For 862.54 it seems like a good price.
Thanks
