Which air hammer bits do you find most useful?
firebox40dash5
I have a dull point for unit bearings and such, a sharpened point, a flat chisel, a vee and a claw cutter, and a 1" hammer. Long versions of most are helpful too, but it doesn't look like they have much of those.
plinker
Northern Wi
long & short hammer tip bits, tapered & straight punch, couple of chisel's 6" & 11" (usually 3/4"),
Specially ground (rounded off) chisel for tapping hydraulic hose fitting's loose.
J
Jawn
Stuck in traffic, GA
What do you find the hammer face one useful for?
I only have a few cheap ones right now... a point I rounded off for a specific task, a chisel that hasn't held up well, a notched chisel that's no better, and a sheet metal cutter that I haven't tried to use. (they came with a cheap air hammer).
greasemonkey44
memphis
I mostly use a good chisel, good taper and a good round bit
Buy Ajax or old forge/Mathew bits, they cut better and last way longer
I have a bunch of other bits but those 3 usually do the job
