Which back pressure tester do you have?
1949 caddyman
Arizona
I took an old O2 single wire sensor & removed the wire & end that goes in exhaust. The GM sensors have a small hollow tube that I put a long vacuum nose on. Worked good & was free.
firebox40dash5
Other than flange-mount Toyotas, what is there that isn't standard M18 on the O2 sensor? I figure if it's got a cat (and needs to keep it) it's got an O2 sensor... and the semi-universal Bosch sensors for Toyotas come with a flange-threaded adapter plate. ;)
We had a Lang at my last shop, it got used like 3 times and never showed a clogged cat. It's a 0-15psi gauge, a fitting, and some vac line.
jgorm
San Diego
You can make one, or buy one. There is one on Amazon for $38. Lots of guys run a couple feet of copper before they go to tubing as a heart sink.
GTA Matt
Zebulon, NC
I had an m18x1.5 adapter that can thread into o2 bungs in my compression tester kit, threaded an adapter into it and can either hook it to my vacuum gauge or pressure transducer.
F
FiendFX
California
What do you use for the flange mount type on toyotas? I actually work on toyotas mainly?
MechanicNamedJohn
I have the Lang version; it's nice. But, the easiest and most accurate would be an oscilloscope with pressure transducer during a running compression test. No need to pull the O2, just remove a spark plug.
1949 caddyman
Arizona
If you have a Scanner look at map sensor. Lower vacuum at 2500 rpm than at idle is a restriction, normaly the exhaust.
firebox40dash5
I never actually used it on Toyotas... but pretty sure I have one of the plates that came with a crappy Bosch sensor, which I had on my truck before I learned that Toyotas hate Bosch.
Here's one on ebay for less than that, though. :D
GTA Matt
Zebulon, NC
I do that often to confirm that yes, there is indeed a restriction, but for vehicles with multiple cats on one bank or cats on both banks, you still have to get your hands dirty to pinpoint which one.
1949 caddyman
Arizona
This is with the vacuum hose. I am using an ipad, is this the one picture problem?
1949 caddyman
Arizona
This oxygen sensor came from a chevy truck? How did you cut off the sensor?
I put the sensor in a vise on the hex nut part . Juat start removing material with plyers. There is ceramic inside, break it off. The wire is removed. I did this 10 years ago, memory fading. Try it with an old sensor, i think you will see what i mean. Yes it was a GM single wire sensor.
F
FiendFX
California
Thanks I will try it.
