Which color is the best and why?
Fredartic
Ste-Sophie, Quebec
Which color do you recommand for the floor and why?
Is there any advantage to put it dark? light? What are the points to considerate for the color's choice?
Gotgone
I bought the sandstone color. Medium dark brown. The brochure said not to use light colors on high traffic areas. Did a test spot in a corner just to see. I think it is a good color for the floor. I also got a bottle of the Shark Grip. I am going to add it to the second coat. I may put a coat of clear on if there isn't enough shine. The salesman said I could just add the Shark Grip to the clear. Since I am not sure whether I will use the clear, I am adding the Grip to the 2nd coat. Bought the larger bottle of Shark Grip so I will have enough for whatever I decide.
dps
No one color is likely to be "best", it depends on your requirements. Medium-light gray is the classic compromise for showing less dirt while still contributing some light reflectance. A "warm" gray will help balance the light qualities from a usually "cool" florescent lighting. Beiges and light tans would be warmer yet.
White floors are best for overall lighting evenness and finding dropped parts. They also make almost anything sitting on them look good, or at least do not distract from cabinetry and vehicles. Shows dirt more than the above colors.
Black is very dramatic and probably makes the widest range of vehicles look good, but is bad for working on them because they reflect so little light back up, and finding dropped parts is really bad. Shows dirt the worst, just like on a car.
The most common "color" for a floor seems to be a red oxide, maybe because for years past it was the most inexpensive because it used red lead. But any "color" is going to be more insistent, that is, you'll notice it more, for better or worse, and of course fewer other colors will look good with them. But the "right" colors will probably look even better than they would on a color-less (white/gray/black) floor. For example, a fairly bright "taxi-cab" yellow floor will really make a white or black car look good, along with red, black, or stainless tool chests/cabinets. A red Ferrari will look good on it (not that a Ferrari probably doesn't look pretty good just about anywhere) as would a lot of hot rods of many colors. But if you get tired of it, obviously it's a big time and/or money expense to change it.
sjsfire
illinois
I did mine in "Gull Gray" not too light, but light enough that if you drop something small you can easily find it.
Wardrum
Wisconsin
I agree with most of what dps said except that I'm not sure I agree with his comment about red oxide being the most common color. In our area, gray is most common by far with a light tan being next most popular.
I went with white for the reasons stated above plus it fits in with my color scheme in the rest of the shop (red, white and black). As with most light colors, it does show the dirt more. It also requires more coats to get even coverage (with the flecks, logos and stripes on my floor, I have 4 color coats and 4 clear coats but that is another story). I left the area under the car plain white so that dropped small parts could be found easier and it works great. And the white floor, walls and ceiling reflect the light so well that I have yet to need a drop light to work under the car.
(in case you're wondering :headscrat, the pail is covering the wiring coming up from the floor for the 4 post lift that went inside the rectangle after these pictures were taken)
JohnZ
Washington, Michigan
I did mine seven years ago in light gray (they called it "taupe"); just about doubled the lighting effectiveness due to its reflectivity. :thumbup:
:beer:
z28toz06
Connecticut
I am torn between red and a gray, But I would really like to do red/gray checkerboard but it looks like a lot of work taping off etc.
burger
Erf
i plan to paint my floor either light grey or light tan when i get to that point (just got my variance). the floors in the machine shop areaa of my work are painted light grey and it seems to be very reflective while hiding most of the dust and dirt. if you plan to work in your garage, light reflection and dirt "hiding" seem to be much higher prioroities than which color will make your ferrari look better.
boiler7904
NW IN
I used Rust Oleum Pro in Tile Red. It was a mistake for a few reasons:
- ***** all of the light out of the garage (what little their is).
- Can't find small dropped parts.
- Scratches show up white or light gray (I have the clear coat)
If I was doing it over, I'd go with the light gray.
snorvet
Northern Illinois
I went with taupe Epoxy-Coat in my detached garage
I'm picking up my sandstone H&C silicone acrylic sealer for the attached garage tomorrow
thrytis
North Carolina
What are you doing in your garage? Just storing your cars, doing non-exacting work like changing your oil, or doing some detailed work? If you are doing detailed work, definitely go with a light color. When i chose my VCT, i carefully selected my color based on the most light reflectivity (Armstrong lists this for each tile color on their website) that would still hide dirt and stains. The tile i picked was 50-54% reflectivity, and it made a huge difference in the amount of light over the gray concrete. Before i had to use a 1000W halogen light in addition to the room lights to do any detailed work, now the room lights provide enough for most stuff.
Gotgone
Grey grey grey. Seems like the most common color. Over the years all of my garages have been one shade or the other of grey. Time for a change. Originally picked sandstone. Painted the pegboards and bench a medium tan. The sandstone looked too dark with that color. Returned the sandstone and got the next lighter color. Just waiting for the floor to finish drying to start sealing. Nothing wrong with grey just too common for me. Old dogs like new tricks (colors).
F
Fredartic
Ste-Sophie, Quebec
What about a very light yellow, butter cream, not lemon or mustard but just a nice yellow? Any objection for not considering yellow?
That's what I'm considering for my garage. The walls will be darker than I was expected: it's the canexel panel pre-painted beige but it looks like between kaki and tan. So, I don't want a dark floor. I don't want the common grey. I was ready for a tan but I have got an idea for yellow cream. When I look the result of the mixed colors on paper, it looks very nice. I am considering to use red tomatoe color on the concrete walls...
dps
That sounds good to me. It should be a pleasant color to be around when working, warm feeling in the winter. Yellow or gold cars probably won't look good on it, but white, silver, black, and reds should look great. Most blues and greens should be good to great (if any of that even matters to you).
I agree; I've got gray and am tired of it. For now, I do color-type work out there and couldn't have the distraction of a large body of color, but someday...
PhantomEB
Medicine Hat, AB, Canuckistan
most garages that do have painted floors around me, and trust me, I am very involved in the offroad community and car guy community here either is grey or cheapass unpainted, followed by the typical "oh that looks cool so lets slap it down with no prep" rustoleum garage paint that they found at Home Depot.
Myself to be totally different am going a light to medium blue for my floor. Grey just seems too "clinical" for me and I want something inviting, not to mention another small detail to bring up conversation wise.
Jay H 237
Torrington, CT
Has anyone done any shades of green? Green is a color I haven't seen used yet.
I think a green floor would look good with white or cream colored walls. A dark green may be too dark but a medium shade, almost like grass, shouldn't be too bad.
If your tool boxes are black or stainless steel then they would go good, however if they are red then unless you want an Xmas looking garage I wouldn't use green on the floor!
Rustang
Los Angeles, CA
In a few months after the slab is cured, I was thinking about going with a really light grey, almost white color. I know all of the warnings against, but I've got hundreds of hours on the push broom and mop already logged in.
Here are some examples....
Maybe I'm just being unrealistic on how clean I'll keep my floors, butI do like the light being reflected off the floor.
PhantomEB
Yeah me too, thats why I originally wanted to stick to light grey or white, white I want to stay away from in case I end up using my future garage to park the DD in all winter. Blue makes it feel warmer when ya wrenching or weldign though?
