Salvage Workshop
All things being equal, if you needed a great all around compressor, Which pump would you chose?
Champion R-15B - Circa 1972
Curtis-Toledo E-57 - Circa 1989
Saylor Beall 705 - Circa 1972
Pictures of each below!
So I have a youtube channel where I restore old tools and equipment, among other things and one of my next projects is to restore and install a proper compressor in my shop!
I was planning to restore the Champion R15B 80 Gal Tank that I acquired awhile back, but JUST as I was starting the process my wife found someone locally getting rid of 2 compressors for a song:
-Curtis-Toledo E-57 Upright with 5HP 3ph motor (80 gal)
-Saylor Beall 705 Horizontal and I am not sure on the tank size or motor size at the moment, I haven't powerwashed them off yet.
So the Champion R-15B Upright functions perfectly not including the pressure switch (bad diaphragm I think), and I just don't trust the tank on it. I did run it up to 180 PSI just to see how well it runs, and it runs and sounds great!
I dont have 3 phase, so I havent fired up the curtis yet, but it is smooth and creates plenty of compressed air just by cranking it by hand, so I dont think there is anything wrong with it internally!
Same goes with the Saylor, I havent fired it up, but it creates compression and moves freely by hand!
Depending on what compressor pump I choose I plan to use the 5HP electric motor from the Champion because its in great working order and its 1 phase. I also plan to use the tank from the Curtis because I trust it much more than the champion, and I want an upright for the location I will be installing it in my shop. These plans are tentative, I'm still figuring our what my plan is for these old girls!
In regards to what I will be using it for, think of it as a compressor for a maker space. Airtools from a blower, air drill, die grinder, paint sprayer, small-med blast cabinet, nail guns, plasma cutter, Machine shop needs, some auto repair needs, and probably uses I don't even know of at the moment! Depends on where my channel takes me!
Which pump would you choose for a shop like mine and why?
Thanks in advance!!
Thanks in advance!!
